RV.Net Open Roads Forum: Truck Campers: how to mount solar panel
 > how to mount solar panel
StirCrazy
Kamloops, BC, Canada
Posted: 08/15/20 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
So I have a 1991 slumber queen with an alumium roof and I am putting a 325 watt panel on it, but the mounting feet wont line up with the rafters. whats the best way to fastent it?
I was thinking of using oak strips to span the rafters and then screw the mounting feet to them, any ideas?
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Ed_Gee
Central Oregon coast
Posted: 08/15/20 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
If you have at least 6 mounting feet, then 3M #4950 doublesided tape would work well, as long as you cleaned that aluminum roof contact points properly.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
CA Traveler
The Western States
Posted: 08/15/20 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
VHB tape and/or aluminum angle.
2014 Grand Cherokee Overland
Bob
June Lake area, California
Posted: 08/15/20 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
I’m for at least eight feet and tape.
Crabbypatty
Long Island, New York
Posted: 08/15/20 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I bought aluminum angle iron. 6 ft piece and cut into 3-4 inch pieces. Bolted to panels then screwed panels into the roof. I applied a healthy amount of dicor sealant under the mounts then on top once screwed in. Works perfectly no leaks. Im not interested in adjusting panels so they are hard mounted.
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
pianotuna
Regina, SK, Canada
Posted: 08/15/20 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Add additional mounts where the rafters are, made from angle aluminum.
Regards, Don
Freep
Wisconsin
Posted: 08/15/20 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Move the mounting feet on the panel. It's just an aluminum frame. Drill new holes and move the feet where you need them to be.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
Paradox123
Pine Junction, CO
Posted: 08/16/20 03:46am Link  |  Quote  |  Print  |  Notify Moderator
I used 3M VHB tape on my fiberglass roof about 10 years ago and the solar panel mounts are still tight. I’d highly recommend VHB tape for this application.
tuna fisher
joshua tree ,ca.
Posted: 08/16/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
As everyone else , use 3N VHB tape then cover with Dicor. Make sure to clean with Alcohol first. My panels are rock solid still after 10 years or so. No holes in roof
2001 GMC DM, 1995 Lance Lite, @005 Eclipse Toyhauler, Toy's!">
StirCrazy
Posted: 08/16/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
was your alumium fully bonded to your plywood? my roof is one piece alumium and only 5/16" plywood on the back half. the alumium skin seams to float for the most part so i have the feeling if I mounted it like that it would just lift the alumium skin off the roof.
