Cummins12V98
on the road
I was trying to show how you can’t tell how much an axle is or is not overweight by how the RV and Truck look.
But hey think what you want.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
garyp4951
TN
Dang, looks level, maybe the tanks were full, or had a bike on the back.
Me Again
Sunbird(Wa)/snowbird(Az)
I believe that is an error/misleading statement in Goodyear's inflation document. No where is there a LRG Endurance available to purchase.
If you go here and look at the actual tires available, the ST235/85R16 is listed as a LRE at 3640.
cummins2014
Utah
Its obviously an error. I am sure it reflects the proper max inflation , and weight on the sidewall. IMO there is a lot of misleading statements with Goodyear .
edited 08/22/20 08:23am by an administrator/moderator *
Cummins12V98
on the road
garyp4951 wrote: Dang, looks level, maybe the tanks were full, or had a bike on the back. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Look at the shadow lines. The frame to ground was 6" more in front than back.
Thermoguy
Graham, WA
From my research, the ST did not come in an 85 size.
ST tires are going to be 235/80R16
LT tires are going to be 238/85R16 -
There isn't much difference in size, but this is what I found when researching tires.
I have 7 year old GY Marathon tires (ST 235/80R16) and had a blow out this past week in Idaho, however, the blowout was due to a failure of my suspension shackles, not the age of the tires. But, I need new tires and should have bought them before this past trip. Not the point however as I was told something would have blown regardless of the age of the tire...
I spent a day at a repair shop waiting for parts. The conversation turned to tires. We talked about the Sailun tires which they sell, the other off brand they sell vs Goodyear LT tires. He wanted to sell me the Sailun but I can get Goodyear LT tires for $100 less per tire. His comment was that LT tires are designed to take a beating, roll for 50K miles or more in all weather, go off road, etc. Basically due what a tire is supposed to do. The ST tires are designed to get driven occasionally, typically only highway, some will put on lots of miles but most drive them in the summer a few trips. Most trailer tires wear out due to age - 5 to 6 years, not due to mileage. Some years ago, manufacturers didn't make specific trailer tires but then marketing saw an opportunity to make a specific tire that didn't need as much research as a truck tire. So, basically, it is a basic tire. Sure, the Sailun G rated is a 16 ply tire vs a LT 10 ply tire. But, in my case, my trailer is 8-9K lbs on the tires, never enough to overload 4 LT tires. As a case in point, I also have a horse trailer. It came with LT tires that lasted 10 years. I now have 4 years on the a set of GY LT tires and they look new. They get driven more often than the 5th wheel, but they are not drying out at all.
The point I am making, if you don't need a G rated tire due to weight, the tire will wear out due to age before it wears out due to mileage. You can spend $1000 bucks on Sailun G rated tires and replace them in 5 or 6 years, or you can put LT or a good ST E rated tires for $600 or less and replace them in 5-6 years.
Travlingman
Jonesborough, TN
Thermoguy wrote: From my research, the ST did not come in an 85 size.
Sailun ST235/85R16
2017 F-350 King Ranch DRW
2014 Landmark Savannah
JIMNLIN
Oklahoma
Travlingman wrote: Thermoguy wrote: From my research, the ST did not come in an 85 size.
Sailun ST235/85R16
And don't forget Carlisle HD in a ST235/85-16 E
And Providers on commercial and rv trailers in a ST235/85-16 E and G
Also Endurance in a ST235/85-16 E.
Looks like many ST tire mfg has a 235/85-16" tire now
fj12ryder
Platte City, MO
The OEM tires that came on my 2010 Fuzion were Carlisle ST235/85-16. Not the HD.
Howard and Peggy
"Don't Panic"
Thermoguy
Graham, WA
Well, now that I look again I see trailer tires in both sizes. My bad. Thought when I researched it about a month ago that was the case. The only thing I see now is that the 80 is about $35 less than the 85 depending on tire manufacture. That might be why I was thinking they were a specific size for the ST tire.
Sorry for posting inaccurate information.
