nykolas
quebec
hi
mostly I use my 5th wheel for spending weekends away from the city and most times I am alone. And boondocking not connections just propane
I've mostly been using coolers but I was curious to know if it is an idea to start up and run my fridge for the weekend.
I'm not sure if it is worth starting up just for 2 days and shutting it down etc.
Also I was curious to have a basic idea of how much propane it would use for the weekend.
Thanks to all of you for your answers this is an awesome forum !
Nicholas
edited 08/17/20 09:49am by nykolas *
frankwp
Calgary, AB, Canada
Just go ahead & use the fridge.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
jdc1
Rescue, Ca
You might use a few ounces for a week to run your refrigerator. It's nothing like an oven or heater.
Bert the Welder
Van. Island
Not sure what you have to do to start it up or shut down? Maybe yours is more complicated them ours.
I just plug in day before, at the house to get it cold and fill it. Run it on propane when camping. Empty when home and leave it off. Wipe it out the next day and prop the door open. Ready for the next outing.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
enblethen
Moses Lake, WA
Are you able to keep rig plugged in? If so, leave the refer on. You do not need to worry about propane as it uses very little.
If not able to keep plugged in, you will need to keep an eye on your battery level, Majority of RV refers require 12 volts DC for control.
If you have a residential refer, you will need to keep rig plugged in to shore power or have a good battery bank.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
camperdave
northern, California
I use mine on all trips. I cannot precool due to parking on a hill at my house, but I start the trip with a bag of ice in the freezer (along with all the cold food in the fridge) and the fridge is cool by the time I arrive at my destination. Propane use is quite small.
Coolers work fine, I'm sure we all used them for years before RVing. But fridges are better. Use it if you got it.
2004 Fleetwood Tioga 29v
Tiger4x4RV
Inland Empire, Southern California
My usual solution is to just use my small 3-way fridge like a cooler: put a lot of frozen bottles of water in it. It stays cold for several days, with the added plus of not having to totally level the truck at every campsite.
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
DrewE
Vermont
As a very, very rough rule of thumb, an RV fridge (in propane mode) uses around a pound of propane a day, possibly a little less, depending on the exact fridge model and the conditions you're using it in. Starting it up for a weekend trip and turning it off afterwards is perfectly sensible, in my opinion. Leaving it on all the time to use it on the weekends is rather wasteful of energy; on electric power, they use a few kWh per day.
(As for leveling, if the RV is level enough for you to be comfortable walking around and cooking and so forth, it's plenty level for the fridge.)
wolfe10
Running the refrigerator takes BOTH propane and 12 VDC.
And if you do turn it on, most take 24 hours to come to operating temperature.
No right or wrong answers, but you need to know that battery power is also needed.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Bishop area, California
I would never not use my TT fridge.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
