RV.Net Open Roads Forum: General RVing Issues: Bullseye dent in fiberglass rv
 > Bullseye dent in fiberglass rv
Mickeyfan0805
SE Wisconsin
Posted: 08/17/20 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
While washing our rig yesterday, I discovered a small dent in the fiberglass. The center of the dent is quite small, with concentric rings, like that of a 'bullseye' formation, extending out to about the size of a nickel. If it were up front or on the side I'd expect a small stone. Being on the rear, I'm not sure what happened. It honestly looks as though it was shot with a BB-gun.
It is not especially apparent, but I'm a bit concerned about water intrusion leading to delamination. Anything I can do to try to repair, or at least secure, this dent so that it doesn't cause increased damage?
RobWNY
Jamestown, NY
Posted: 08/17/20 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
It probably WAS shot with a BB gun. Is the fiberglass cracked? I'd probably go to an automotive store and buy a spray can of clear coat and put on several layers and call it good. Another option is to fill it with bondo, sand it smooth, prime it, paint it, and cover it with graphics. Unless you're good at fiberglass repair or want to spend a lot of money to have it repaired those are the options I can think of.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Camping near Pearsonville, CA
Posted: 08/17/20 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
"buy a spray can of clear coat and put on several layers and call it good"
Very good suggestion.
garyhaupt
Penticton, BC..land of wine, sun, retirees....
Posted: 08/17/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Take a look at this product. I have a tube for a repair that I have yet to do. Called Magic Easy..from Australia..I bought mine in eastern Canada. The address I have included is your US connection.
https://www.ab-marine.com/magicezy/
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
Retired JSO
North Georgia Mountains
Posted: 08/17/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Gary Haupt
Amazon $24.99 ships free.
Lynnmor
Red Lion
Posted: 08/17/20 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
You should look at how your wall is built, calling most of these smooth side trailers “fiberglass” is not accurate, most are very thin plywood with a paper thin coating that resembles fiberglass. Check a cutout where there may be an edge exposed. I mention this because you are making more of a wood repair rather than a repair like one would do on a boat. The product mentioned above shows broken wood, so it might be OK, just do your homework before proceeding.
Bumpyroad
Virginia
Posted: 08/17/20 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
white bondo and spray paint
bumpy
Super_Dave
Harrisville, UT
Posted: 08/17/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Color matching caulking.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
johnhicks
Wandering below the Gnat Line
Posted: 08/17/20 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
It may have been caused by somethine poking outward rather than an external impact, so check that. As mentioned, if it's not too obvious I'd hit it with some clear coat. To do it right...sanding, applying a bit of gelcoat, sanding again and again and painting to match is a royal pain and likely to just look like a patched spot.
-jbh-
dodge guy
Bartlett IL
Posted: 08/17/20 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Order a nice heavy duty vinyl sticker of your choice and cover it!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
