BurbMan
Islip, Long Island
Looking back at at pictures of the Lance 811 before I took it apart and I see that there is a metal piece that goes below the cab window, see arrow in pic. I recalled that it fastened below the cab window, but in the pic it looks like it shares the lower set of screws with the window frame.
It's just a piece of stamped steel. Now that I sealed the bejeezus out of that window frame with butyl tape and proflex, before I try to get this piece in, what's it do? Do I need it?
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
jdc1
Rescue, Ca
Keeps leaves out of the bed and diverts water?
Darryl&Rita
Grande Prairie, Alberta
jdc1 wrote: Keeps leaves out of the bed and diverts water?
Gets my vote. Seen rubber flaps there, too.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
joerg68
St. Ingbert, Germany
Many campers don't have this. I know mine doesn't.
AnEv942
CA
It isn't needed- it is just a diverter. Ours is narrow, pretty ineffective as campers rubber bumpers hold camper back enough water running off hits top of bed rail & can still run into bed. If you have room it doesnt have to go behind window and could be lowered.
Our camper projects page
BurbMan
Islip, Long Island
I haven't actually had this camper on the truck yet, so maybe I'll hold off reinstalling that piece until I see how it sits. I was reading the other thread about the cab-to-camper seal around the window and @kayteg got me thinking about fabricating something with a couple of pool noodles.
kohldad
Goose Creek, SC
My Lance 815 has it and it keeps the bed dry even during down pours. With my camper sitting back 1-1/2" from the bed, looks like the water would drip off the edge into the bed but it doesn't because of the wind. Just looked at mine and it does share the bottom window screws.
If the bottom of you camper is going to sit directly on a rubber mat, make sure it won't get hurt from sitting in water. If this is taken care of, then no issue leaving it off.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Joe417
AL
I have one just above the window. Before putting it on, our step up to the bed would get wet when we were driving in heavy down pours.
No wet steps since.
With it below the window it would keep some of the water from running down the front wall and into the bed
Joe & Evelyn
JoeChiOhki
Sauvie Island, OR
Rain deflection cap, the idea behind them is they're used to deflect rain away from the leading edge of the seam or area beneath so that there's less chance of water infiltration.
In this case, the idea is to deflect the rain/air flow coming over the cab and down the front of the camper into the gap between the truck bed and the cab so that it has less chance of puddling up between the front of the truck bed and the camper, as rain water in that area is being more forcibly driven that spray washing in via the slip stream along the sides.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
Ski Pro 3
bye
Does that window come out, removable? Maybe it has something to do with holding in the window?
