RV.Net Open Roads Forum: Tech Issues: Shurflo water pump issue
 > Shurflo water pump issue
mikefos
Fredericksburg, TX
Posted: 08/18/20 08:51am Link  |  Quote  |  Print  |  Notify Moderator
We are on the road in a campground and have the Shurflo 4008-101-A65 pump. It suddenly stopped pumping water but still runs. Cleaned the strainer of quite a bit of mineral sediment, although it was cleaned while winterizing last. Anyway, the pump won't prime but runs. Thinking about replacing it if the exact same one fits w/o any plumbing line modifications. Perhaps before ordering one I should attempt to take apart and see if anything is plugged up inside. How difficult is it to disassemble and clean? Is it worth the effort? Pump is 8 years old.
Mike
Mike and Kim
2012 Jayco Eagle Super Lite 308RETS, TST 507 TPMS
2010 Chevy 2500HD, Duramax/Allison, 2WD, Long Bed, Crew Cab, Duraflaps, AMP Bedstep
Equal-i-zer 1400/14K Hitch
corvettekent
Marysville, WA
Posted: 08/18/20 09:16am Link  |  Quote  |  Print  |  Notify Moderator
They are very easy to take apart, clean, and reassemble.
You can also buy just the pump without the motor on Amazon.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
dhull
apple valley
Posted: 08/18/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
If you have a winterizing pickup hose hookup to the pump then open it up fill with water and blow into it while running the pump with a spigot open. Your manually priming it. This has worked for me with same pump. But your is 8 years old....
Gjac
Milford, CT
Posted: 08/18/20 10:09am Link  |  Quote  |  Print  |  Notify Moderator
It is easy to take apart and clean the rubber diaphragm, the problem I had was sealing it back up. After several tries of evenly torquing the parting plane bolts I finally had to add some silicone sealer at the parting plane The flange of the rubber diaphragm is suppose to act as a gasket but needed a little help. Mine was 18 years old when it would not prime and was drawing air in at the parting plane and leaking slightly also. Yours is much newer and should re seal without any added sealant.
mikefos
Fredericksburg, TX
Posted: 08/19/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tip. Tried it but didn't help. I'll pull out the pump and attempt disassembly to see if something inside is clogging things up or broken. In the background I'll price a replacement.
Mike
mobeewan
Hampton, Va
Posted: 08/19/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure your not sucking in any air through the pump inlet tubing. The slightest bit can keep the pump from priming. Recheck to make sure the strainer bowl is properly seated and is tight.
Check any flexible vinyl tubing between the tank and pump. I have had to replace the short pieces of vinyl tubing on the pump inlet a couple times because the tubing had lost its pliability and was no longer sealing on the fitting hose barbs no matter how much I tightened the hose clamps. Air was being sucked in between the tubing and barbs. New tubing and new hose clamps solved the problem.
mikefos
Fredericksburg, TX
Posted: 08/20/20 07:25am Link  |  Quote  |  Print  |  Notify Moderator
I'll check this, although the inlet tubing goes through the floor to the tank so don't know how I can check that segment. I'll check what I can see and access right before the pump. I would have thought though that blowing water through the antifreeze tube into the pump would have at least primed it some.
Thanks,
Mike
