RV.Net Open Roads Forum: Class A Motorhomes: First time out problems
 > First time out problems
Gjac
Milford, CT
Posted: 08/24/20 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
The round knobs on top of the joy sticks unscrew so you can remove the plate.
Lt46
Central Florida
Posted: 08/25/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
I've never had to remove a control stick so I can't answer that. Vacuuming the contact plate and surrounding area has always helped when things got wonky. The yellow light signal comes from the level sensor mounted in one of your exterior compartments. The red light should light if it senses the parking brake is engaged. Have you tried stepping on and releasing the p-brake a few times to see if that will get the red light to come on?
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
Gjac
Milford, CT
Posted: 08/25/20 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
You don't remove the stick just the knobs on top of the 3 control sticks and the top plate comes right off after removing 4 screws. You would be surprised to see the dirt and stuff under the plate. The center one will spin when you unscrew the knob so you have to hold the shaft.
* This post was edited 08/25/20 01:09pm by Gjac *
