RV.Net Open Roads Forum: Truck Campers: Truck Camper Jacks
 > Truck Camper Jacks
Randall Rice
38075
Posted: 08/20/20 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have problem with freezing HappiJac jacks? I have replaced two motor assemblies and have another going bad. I know there is a new style motor and I am wondering if it is better and a direct replacement of the old style.
guidry
Texas Cajun
Posted: 08/21/20 05:56am Link  |  Quote  |  Print  |  Notify Moderator
I replaced mine with refurbished motors. I then took mine apart and lubed the inside (there’s instructions online). Never had a problem after that.
Bert the Welder
Van. Island
Posted: 08/21/20 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
It doesn't get that cold where I am and they wouldn't fit in my upright or chest, so can't help you....
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
DWeikert
York, PA
Posted: 08/22/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I think I've returned Hj motors for rebuild 5 or 6 times after seizing internally. One motor I had seize after one season. Had it repaired and midway through the next season it was seized again. Hj motors have a water intrusion problem that I don't know if they have ever fixed. I store my camper in a carport these days and I haven't had any problems since. I also picked up a spare motor so it may just be a Murphy thing. Now that I have a spare I won't have any failures. The first couple motors I returned they suggested wrapping a plastic bag over the motor head to protect it from the weather. Pretty poor design for a part that is expected to be used outdoors.
In case the motor is just sitting on a dead spot, you can try using the hand crank with the motor still engaged and see if that frees it. Didn't work for me but YMMV.
Dan
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
Bert the Welder
Van. Island
Posted: 08/22/20 10:44am Link  |  Quote  |  Print  |  Notify Moderator
That is just an outrageous suggestion. The only bag should be over the head of the person that suggested that.
54suds
adk mts.
Posted: 08/22/20 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Bert that's the typical help you can expect from CRAPPI JAC ( LIPPERT junk CORP) I have 8 spare motors in my parts bin got a super deal once on e bay and lost count of the number of jacks ive had to rebuilt or buy replacements because of trash construction and subgrade componenents and not once in repeated contacts with hj was company helpful in any way .
* This post was edited 08/22/20 07:12pm by 54suds *
2021 Chev 6.6 duramax ltz DBL cab,drw,4x/torklift tdn's,
1999 Bigfoot 1011
stevenal
Newport, OR, USA
Posted: 08/23/20 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I rebuilt one that I keep for a spare. Any water that gets inside will sit on the lower bearing until it rusts. The rebuild included drilling holes in the end cap to let the water escape. I don't know if the new vertical motor is better.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
Bert the Welder
Van. Island
Posted: 08/24/20 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Gotcha. Mental note to self. Does seem over the years, HJ's were the topic of more problems then others. And if they've been bought by a worse company.....
JimK-NY
NY
Posted: 08/24/20 11:51am Link  |  Quote  |  Print  |  Notify Moderator
I have lost 2 motors due to water intrusion. The seals are just plain poor and do not work over a period of years. I even tried sealing plastic bags over the motors. Now I use caulk and gorilla tape around the joints. At least that has now worked for 2 years.
Iceworm
British Columbia
Posted: 09/01/20 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
I had to replace one of my Happijack drive units recently. I contacted the company and requested to buy just a replacement electric motor as the gear assembly etc was fine, just the motor was seized. There was no reply from them, the silence was deafening!! Too bad they seem to be the only company producing these motor assemblies, some competition might help! I managed to get the motor apart after soaking the two through bolts for 3 weeks in penetrating oil to see what was going on with the corrosion issue. It was amazing how badly corroded the inside was. I did get the motor working again and it will be my backup unit when one of the other 3 seizes up!
If I could figure out how to post a photo to this post it would be great.
