RV.Net Open Roads Forum: Class A Motorhomes: Norcold 1210 freezer cold refrigerator warm
 > Norcold 1210 freezer cold refrigerator warm
ferndaleflyer
everywhere
Posted: 08/21/20 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Spent 2 weeks out in our DP and noticed the last couple of days refrigerator didn't seem cool enough. It has sat a week now hooked up to shore power and last night it was -10 in the freezer and 60 in the refrigerator. It is 3 years old. Electric heater and burner are fine and no codes on the unit. The upper part of the coils weren't hot and the fins in the frig were at room temp. I put a dorm refrigerator in there as we are rolling out today. Any suggestions? Come in Doug!!!
dougrainer
Carrolton, Texas
Posted: 08/21/20 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Yes, the rear cooling fans are not operating. Doug
ferndaleflyer
everywhere
Posted: 08/21/20 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Doug---I'll get into that when I get back in here Monday. Can I see and hear them from the top???
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 08/21/20 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Doug knows a lot more than me, but I would expect the coils to be hot if the fans aren't working. OP, I can hear our refer fans when they cycle on.
* This post was edited 08/21/20 12:47pm by hotjag1 *
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
Executive
Posted: 08/21/20 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Nope and nope. Unfortunately, IIRC the fans are not accessible from the back without pulling the fridge. You might be able to add some extra ones up top, I did, but that will be a temp fix only....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
dougrainer
Carrolton, Texas
Posted: 08/21/20 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
If you can get a small 120 volt fan and install it at the rear bottom access blowing UP, that will get you until you fix or replace the 2 fans. Now, you have to pull the refer to replace the fans and/or the fan tstat. If you pull the refer, you replace BOTH Fans AND the Fan tstat which is mounted on the upper condenser fins. Even if the Fans are good and the tstat is bad, replace all 3. Doug
https://www.amazon.com/Norcold-618093-DC-Fan-Thermostat/dp/B004RCX95U
https://www.dyersonline.com/norcold-repl........22KCt6wIVL_LjBx2SKQbkEAQYAiABEgJD7fD_BwE
tropical36
Southwest Florida_USA
Posted: 08/22/20 08:41am Link  |  Quote  |  Print  |  Notify Moderator
It's always been a battle for keeping a NEVERCOLD fridge temp. under 40F, with the best of them, from the git go.
I can't imagine pulling the fridge for doing any kind of repair, without just doing an RC refrigeration conversion, while you're at it.
Choice of a compressor type or staying with the RV style is available, as well.
That's the only way, it's ever going to be right for proper cooling.
Once the refrigerant cell fails and it will eventually, you're done anyway and not to mention the possible fire safety concerns, that come with it.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
dougrainer
Carrolton, Texas
Posted: 08/22/20 11:57am Link  |  Quote  |  Print  |  Notify Moderator
It is not hard to get a Norcold down to 32 degrees and keep it there. MOST cooling problems are caused by BAD INSTALLATION by the Coach builder. AS to pulling the refer. From start to finish it takes me about 1 hour to partially pull and replace BOTH fans and the Fan tstat. I also run a 2 wire jumper from the sides of the fan tstat down behind by the rear control board to manually make the fans run by bypassing the fan tstst. This is for testing. Now, the Norcold Flat rate is 3.2 hours to do what I just detailed except for the 2 wire jumper. If you would follow some of the 1200/1210 threads you would see, once the RV'er gets the Rear of the Norcold baffled and installed correctly, the cooling is just fine. Doug
Ivylog
Blairsville, GA and WPB, FL.
Posted: 08/22/20 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
A platform almost as high as the bottom of the refrigerator makes it easy to slide it out...3 screws top/bottom hold it in and maybe 1 at the back into the floor. Start by prying the metal bottom (at the back) away from the wall. Once out a couple of inches you can finish from inside.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
ferndaleflyer
everywhere
Posted: 08/24/20 09:28am Link  |  Quote  |  Print  |  Notify Moderator
OK, back home now and its raining. I had a small 12 volt fan in the garage with an on/off switch and jerry rigged it into the bottom at the back blowing up before we left. It got the freezer below zero and the refrig was 38. Guess that tells me something. When checking it sometimes the cooling coils were cool and other times to hot to touch. There was nothing in the frig at all. What does that tell me?
