RV.Net Open Roads Forum: Fifth-Wheels: advice on 5th wheel hitch option
 > advice on 5th wheel hitch option
mrad
Prineton, MN
Posted: 08/21/20 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
We have recently moved from a TT to a 5th wheel and will need to install a 5th wheel hitch. Originally I was going going to go the cost conscience route and put in a B&W patriot manual slider that was recommended by the local RV repair dealership. However, I am now thinking I should look long-range and probably go with a long term vision. I have read where some have had manual sliders and ended up with dents in the cab because they did not engage the slider.
I am looking for advice on what hitch I should install. The TV is a 2013 Chevrolet short box. the distance from the cab to end the tailgate when closed os 6"10 1/2".
I like the Andersson ultimate 5th wheel hitch but have read some posts where users have stated that it bends. Would appreciate all opinions
the local shop said he has a used pullrite auto glide that is being sold on consignment for $700 and could be installed for another $500 that came off the same TV I have and would not require any additional parts. Is that a fair price?
* This post was edited 08/21/20 02:42pm by mrad *
ford truck guy
Pennsylvania
Posted: 08/21/20 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
I used a Pullrite Super Glide for many years of problem free towing. The price of $700.00 would have to depend on the condition and functionality of the hitch..
IF it is in good working order, its worth it ...The good thing is that Pullrite is GREAT to deal with if parts are needed.....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Tyler0215
Iowa
Posted: 08/21/20 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Fair price? I don't know, have you checked the price of a new one?
MFL
Midwest
Posted: 08/21/20 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
First of all, If your FW has the rounded nose, you won't need a sliding hitch.
GM has the longest distance from rear axle center, to back of cab. That, and the fact that most newer FWs have rounded front corners, that are purpose designed to tow with a 6.5 bed truck. If you think you still have to have a slider, for that once every five years, that you get in an extreme backup, then get the Patriot manual slider.
Since 99, I've been towing a FWs with Fords, that have 2"s less distance from axle center to cab than your GM, and never come close to hitting cab.
A Patriot non-slider would be a good choice for you, and they are adjustable ahead/back, very easily.
Jerry
Old-Biscuit
Verde Valley
Posted: 08/21/20 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
$1100 Plus for 16K
Pricing goes UP depending on Model and Weight Rating
$700 is a pretty decent price for use provided it has not been ABUSED
$500 installation cost?????
US NAVY------USS Decatur DDG31
4x4ord
Alberta
Posted: 08/21/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
$500 is too much for installation in my opinion. If it came out of your truck you should be able to install it yourself. Some of us with short box trucks have no use for a sliding hitch but I agree with you that if you get a slider it should be an auto slide. The auto slide hitches can be a little more difficult to hitch up. I am satisfied with my short box and B&W Companion.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
mrad
Prineton, MN
Posted: 08/21/20 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
What is the advantage to the companion hitch?? It did not come out of my truck but a truck of the same year and model
* This post was edited 08/21/20 05:33pm by mrad *
azdryheat
Tucson, AZ
Posted: 08/21/20 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you want the hitch to do all the thinking for you, get the automatic one.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Splashers3
Oakville, MD
Posted: 08/21/20 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 2008 GMC2500 D/A with the 6.5' bed. We towed a Cedar Creek Silverback for 10 years using a Husky manual slider. I NEVER had to use the slider and my trailer was very close to 90 deg. I will add, that the corners were "cut" out which provided more turning room, but I was never worried. It was comforting to know that if I needed it, I had it.
Good Luck.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
klr650goldwing
minnesota
Posted: 08/21/20 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Pullrite hitch and really like it. Completely easy to hook up and disconnect. We have never had a problem of any kind.
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
