RV.Net Open Roads Forum: Travel Trailers: Table top propane grill help needed.
 > Table top propane grill help needed.
jotityra
michigan
Posted: 08/21/20 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a Blackstone griddle to cook with while camping. I don't really like it but will probably use it for making breakfast only. I bought a hose with the quick connect fitting to plug it into the back of the camper which worked great. Now I bought a cheap mr bar-b-Q grill and thought I would do the same but I'm not sure I can do it with the fittings on this grill. The regulator threads into the burner and there is an orifice on the end so I think I need that connected to the grill, but I want to bypass the regulator on the grill because the camper already has the regulator on it. I'm not sure if they make fittings like I need to go right into the burner to take the place of the regulator. [image]
2015 Jayco Jay Flight 26BH. Towing with a 2020 F150 supercrew 4x4 with a 5.0L V8 and 3.55 rear end
naturist
Lynchburg, VA
Posted: 08/21/20 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Nope. No can do. The control valve is part of the regulator. The office is not part of the regulator, it is used to inject a stream of regulated gas into the air in the mixing chamber. Because the control valve is part of the regulator, this device is not a good candidate for use on the low pressure propane system on your rv. It could work if you put a Tee in the high pressure line, but I don’t recommend that.
mobeewan
Hampton, Va
Posted: 08/22/20 02:55am Link  |  Quote  |  Print  |  Notify Moderator
I can barely read the text, could you please make the pictures even bigger so I can't read it at all I would appreciate it? Thank you.
jotityra
michigan
Posted: 08/22/20 03:46am Link  |  Quote  |  Print  |  Notify Moderator
That's what I thought but I wanted to check to see if anyone knew, or did anything to make it work. I guess I can either get a hose and attach right to the tank, or just use the small bottles and re-fill them as needed.
jotityra
michigan
Posted: 08/22/20 05:49am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure, let me try.
ktmrfs
Portland, Oregon
Posted: 08/22/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
you need to buy the blackstone nipple for use with a low pressure regulated supply along with an appropriate hose connection to the trailer regulated propane. You can't use the grill with the stock regulator and a low pressure source at the same time.
2011 Keystone Outback 295RE
jotityra
michigan
Posted: 08/22/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Yes. That's what I have for the Blackstone, works great for the Blackstone.
