RV.Net Open Roads Forum: Truck Campers: Repairing soft floor in my wolf creek
 > Repairing soft floor in my wolf creek
anutami
Ramona
Posted: 08/22/20 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Well, after many many nights in my TC the 1/4” floor in my wolf creek is becoming soft in and around the kitchen area. Apparently the 1/4” floor can’t really accommodate my 200+ weight cooking in the kitchen and stepping down from the cabover!! a lot of LOL!!!
I don’t think this topic has really come up and of course it’s not something I focused on when looking and buying. I remember a thread from someone saying “that is all you need” well I need to fix this before it gets worse so my question is?
What do I do? The best fix I am looking at is to pull the bottom off, remove the fresh water tank and reinforce the floor which is going to be a Pain. Any other ideas?
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
352
Oxfofd, Fl
Posted: 08/22/20 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Why do people say they have soft floors? THEY ARE ROTTEN. If it is rotten find the leak first and then rip out all the floors and replace.
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
jdc1
Rescue, Ca
Posted: 08/22/20 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Or get a metal plate and cover the area with that and a decent rug
jimh425
Western MT
Posted: 08/22/20 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I’d think about adding starboard or aluminum plate. 1/4 inch is pretty thin. Depending on how hard it is to get to the floor, I’d try to replace as much as you can. There is also many different finishes of vinyl flooring that could be used to update the look to even a “wood” flooring look if you wanted.
But, before I’d do that ... I’d call the manufacturer if not for them standing behind it, but at least for information on what they think is the best way to fix it.
deltabravo
Spokane, WA
Posted: 08/22/20 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I am not terribly convinced that Northwood would use a 1/4 piece of plywood as the floor material. That thin of wood won't support much weight at all.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
MORSNOW
Mountain Home, ID
Posted: 08/22/20 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Install laminate flooring over the vinyl, that'll add strength.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
Posted: 08/22/20 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Well is it the joists or the plywood that’s fatigued? Assuming not rotten.
I’d strip off the linoleum or whatever and add another sub floor or whatever. Seem way easier to raise the floor say 1/2” than tear the camper apart.
2017 Heartland Torque T29
anutami
Ramona
Posted: 08/23/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I do have access to the basement from the cabover step
Basically they have the flooring laid on top of a 1/4” piece of something then block styrofoam with another piece of 1/4” something (not sure if I would call it plywood) supported by the aluminum trusses spaced every 3 feet I believe.
It appears to be the same type of construction in the roof heres a pic of the roof when I removed the vent and installed some fans
And here is where the soft spot is
MORSNOW
Mountain Home, ID
Posted: 08/23/20 09:54am Link  |  Quote  |  Print  |  Notify Moderator
I have PDF copies of the entire WC850 frame drawings, here is a screenshot of the floor. I'm not seeing any cross bracing where your soft spot is.
jimh425
Western MT
Posted: 08/23/20 10:04am Link  |  Quote  |  Print  |  Notify Moderator
It doesn’t look like it’s damaged. Have you thought about adding cross bracing from below? That would probably be a lot easier. But, I’d still give the manufacturer a shout.
