RV.Net Open Roads Forum: Truck Campers: Cheater Vent - Air Admittance Valve
 > Cheater Vent - Air Admittance Valve
Camper_Jeff_&_Kelli
Seattle
Posted: 08/23/20 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Get a better AAV valve, not the cheap one.[image]
About 25 bucks.
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
Rover_Bill
NE. Ohio
Posted: 08/23/20 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
My AAV's (one at kitchen sink and one at bathroom sink) will occasionally jam open when dumping the full grey tank. Simple maintenance is to unscrew the AAV and shake it until the internal rubber seal rattles. If it doesn't rattle then I stick a thin screw driver in the internal slots and bump the seal loose.
2015 GMC Canyon 3.6L V6 4X4 TowHaul SLE ExtCab Bronze
2016 Keystone Passport GT 2670BH
ReCurve R6 hitch, DirecLink brake controller
2005 Suzuki C50 2006 Suzuki S40
Kayteg1
California > Nevada
Posted: 08/24/20 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Rover_Bill wrote:
My AAV's (one at kitchen sink and one at bathroom sink) will occasionally jam open when dumping the full grey tank. ..
You probably have quite common case that main tank vent pipe is inserted few inches inside the tank.
That was common issue on some motorhome black tanks and develop procedure called "harpooning"
Hacksaw blade attached to long pole inserted via 3" drain pipe would allow cutting too long pipe inside the tank.
No clue how to do it on gray tank though.
Freep
Wisconsin
Posted: 08/24/20 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
About 25 bucks.
This is the one I bought and still ran into issues, until I sealed it. When this valve didn't help I just sealed it up and made sure the sink drains were closed when not in use.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
