RV.Net Open Roads Forum: Class A Motorhomes: What The Heck???
way2roll
Wilmington NC
Posted: 08/25/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
jkc306 wrote:
Retracing my steps I identified errant house batt cable connection. disconnected this one cable from pos post to neg post. using only house batts, interior lights, slide-outs, awning etc working again. connected chassis battery no smoke, engine started. Shore power also working again. Seems i am now back to my original problem: LCI levelers will not retract. Did the reset at panel - that did not help; 15amp fuse in pump compartment ok. Here is a picture of the house batts [image] don't know that it will be useful...
Your positive posts seem to be connected but your negative posts still seem to be missing a cable to connect them.
2020 FR Cedar Ridge Silverback 29rw
rgatijnet1
Posted: 08/25/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
As long as the two negative posts both go to a common ground, they do not need to be connected together as the ground will connect them.
Going back to your ORIGINAL post, you said that you smelled an electrical odor from the house battery area. Usually when there is an odor, something is usually fried and is no longer working as designed. I would look for whatever burned and start from there. Check all fuses even if they look good. You can also apply 12 volt power to your jack pump and see if it operates. You have a few different interlocks that must be in the correct position before your jacks will operate. It might be time to go back to your manual and make sure that you are trying to retract them according to the book.
jkc306
95901
Posted: 08/25/20 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
WoW, like the saying goes KISS...The house battery cabling resolved. Everything works whether shore power or house batteries; chassis battery is good - engine starts right up. As for levelers turns out i tripped two buss fuses. Levelers operational, generator too! I continue to learn much from your advice - becoming a better RV'r. Now we have to reconfigure our road trip - Thank you everyone!
John Contreras
Executive
Posted: 08/25/20 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hurray! and it didn't cost you much...just some grey hairs... [emoticon] Oh! and a red spot where you slapped your forehead......Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
rgatijnet1
Now go out and enjoy yourself. Glad things got resolved.
jorbill2or
Full time
Posted: 08/25/20 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Perfect .. save what you can of your trip and go. I hate electrical problems but you had a good outcome with little out of pocket it sounds .. Thanks for the update
Bill
way2roll
Wilmington NC
Posted: 08/25/20 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Awesome!!
oldave
Tx
Posted: 08/26/20 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Great news
We all learn this way
