CaLBaR
Ontario, Canada
dryfly wrote: So, as per my OP...........no suggestions for a quality brand of grease guns?
DeWalt makes a good cordless 10,000 PSI grease gun.
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
RCMAN46
NorthWest
To the OP
Have the wet bolts ever taken grease?
If not then you need to remove them and find out what is wrong. When I did my wet bolts I found several bolts had not been properly drilled. Lippert replaced the bolts.
RJsfishin
Winston Or.
Change out the grease zerk, and drill out the bolt
one grease gun is as good as another, most all will do 10K psi
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
dryfly
RCMAN46 wrote: To the OP
They have never taken grease. My plan has been to remove bolts as a last resort after trying several other solutions first. I will have to buy heavier jack stands if I go that route.
To those giving suggestions on grease guns, thanks.
RCMAN46
NorthWest
dryfly wrote: RCMAN46 wrote: To the OP
I am almost sure you will find the bolts were not drilled correctly. If you do a search on wet bolts you will find the bolts that were not drilled properly is a common problem particularly with the Lippert bolts although I believe there are others as I suspect all of the bolts come from China.
