dryfly
I'm having issues getting grease into the some of wet bolts of my trailer. I've tried the usual remedy of lifting the trailer to decrease weight off the axles with no results.
Before I try to remove the wet bolt for inspection/orientation I'd like to try a 10,000 psi grease gun and possibly a Lock N' Lube coupler. Can anyone suggest a quality grease gun?
midnightsadie
ohio
change the zert fitting. can you apply some heat.
corvettekent
Marysville, WA
Is this a new wet bolt kit or is it old? If it is old with old grease you might want to try a propane torch to heat the grease in the wet bolts.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
ScottG
Bothell Wa.
Deleted
edited 08/24/20 07:50pm by ScottG *
Lynnmor
Red Lion
If you jacked right next to the spring hanger you are trying to grease and it didn't work, it is time to pull the bolt and see what is going on. That higher pressure gun will do little to help you. If you do the math, that tiny hole will deliver a psi number much smaller than you imagine.
I have suggested several times on here to cut a figure 8 inside the bushing to give the grease a path. Only feedback I got was criticism.
CaLBaR
Ontario, Canada
I wouldn't waste your time with a different grease gun. I had 2 that were giving me problems and went the lol n lube and pneumatic grease gun and they still would not take grease. Pulled both of them, ensured that they would take grease and re-installed them in the correct orientation. All good now. Should have done that in the first place and saved myself some money and aggravation.
Rob
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
bukhrn
Lanexa, Va
if you've got room enough to tap with a hammer, try this, https://www.zerkzapper.com/the-zerk-zapper-tool/
2007 Forester 2941DS
2014 Ford Focus
Bert the Welder
Van. Island
This is AVE. He's played with the Milwaukee and it's got yer 10,000 psi's of pure hot dog slicing, apple penetrating chooch.
https://www.youtube.com/watch?v=nFId_NB6Ar8
And he's funny as he.ll....
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
dryfly
So, as per my OP...........no suggestions for a quality brand of grease guns?
edited 08/24/20 07:34pm by dryfly *
Wherever I happen to park
JC Whitny used to sell a ram. it was basically device that snapped onto the ZERK fitting. you filled it with oil and wacked it with a hammer. I suspect 10,000 PSI was a medium tap wack it you might well hit 100,000 psi designed to blast the zerk clear Far as I know the company is still in business.
One example Google Found
Home is where I park it.
