RV.Net Open Roads Forum: Class A Motorhomes: Converter box location 1983 southwind
 > Converter box location 1983 southwind
Aprillynn
California
Posted: 08/24/20 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Can anyone tell me where the converter box is located in my 1983 southwind RV? This is my first time! Thank you
dougrainer
Carrolton, Texas
Posted: 08/24/20 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
1983. It should be part of the 120 breaker and 12 volt fuse panel box. Doug
RustyMacIntosh
Fresno, Cal
Posted: 08/25/20 05:46am Link  |  Quote  |  Print  |  Notify Moderator
my 96 Bounder which is made by the same company (I THINK) is located on the passenger side outside panel, to the left of the entry door. Its screwed to the inner wall.
I just replaced mine, takes about 10 minutes, and 20 minutes to straighten out my back and butt after getting up off the ground.
MrWizard
Traveling
Posted: 08/25/20 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Doug is right
The converter in your 83
Is part of the breaker box power center
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
