RV.Net Open Roads Forum: Tech Issues: Onan 7000/ac
 > Onan 7000/ac
Carolinamobile
North Carolina
Posted: 08/25/20 10:24am Link  |  Quote  |  Print  |  Notify Moderator
I have an Onan 7000 with 3780 hours. About a month ago the generator would start with no power. We changed the brushes and transfer switch and it was fine. Last week my ac started tripping the breaker on the generator and the compressor would turn on and off. Today, with the ac on the generator would start sputtering and stalling but no flipped breaker. Any idea what’s going on? I don’t know where to start.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 08/25/20 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Start by finding out WHICH OF THE TWO is at fault
Carolinamobile
North Carolina
Posted: 08/25/20 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Yes, that’s what I’m trying to figure out. I’m assuming A/C but not sure where to start in my search for the culprit.
MrWizard
Traveling
Posted: 08/25/20 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off the A/C
Get some other loads to run from the generator,
Electric heaters, air compressors, coffee maker , water heater and fridge on electric
Load up the generator with as many loads on different circuits as possible
Does the generator handle it ?
If so you have an A/C problem
Radiate The Happy
1997 F53 Bounder 36s
Kpackpackkelley
Bryan tx
Posted: 08/25/20 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
Turn off the A/C
Good advice and I’ll add a clamp on ac multimeter and check you starting amps when ac runs and the compressor kicks in.
 > Onan 7000/ac
