RV.Net Open Roads Forum: location of neg lead fm battery in IOTA distribution panel?
 > location of neg lead fm battery in IOTA distribution panel?
Rhett25
Redding, CA
Posted: 08/26/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Looking for neg lead from battery at the distribution panel. Looking to install a shunt and meter. I see the pos connection from the battery and the pos lead to the converter. The remaining leads appear supplies from a fuse to dc service.
Panel appears to be an IOTA 3045.
Thanks
CA Traveler
The Western States
Posted: 08/26/20 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Battery negative leads usually go to frame ground which is where the shunt needs to be installed.
2014 Grand Cherokee Overland
Bob
Fisherman
Angus, Ontario, Canada
Posted: 08/26/20 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
What Rhett25 said, they are too cheap to install an 8 or 10 ga. ground wire (negative) from the battery location to the distribution panel. Found the same on mine. Battery is grounded at the front of the trailer and they run another wire from the frame up through the floor to the distribution panel. Save 15 feet of wire, yet need to install 2 ground points on the frame that will corrode quickly.
MrWizard
Traveling
Posted: 08/26/20 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
The SHUNT can be in the positive wire
The shunt doesn't care
It's just usually easier to install it on the negative lead, because there is less wiring to contend with ( normally done at the battery where there are several wires connected to the positive post ) ( you don't have that concern inside the iota with only one positive wire going to the battery )
Just reverse the polarity of the signal wires from the way shown for the normal installation in the negative lead
As long as it shows plus amp flow when charging
And minus amp flow when discharging
You are good
* This post was edited 08/26/20 08:12pm by MrWizard *
Radiate The Happy
1997 F53 Bounder 36s
DrewE
Vermont
Posted: 08/27/20 12:56am Link  |  Quote  |  Print  |  Notify Moderator
You are good
For analog meters, this is true. It's also true for digital meters where the sensing is isolated from the meter's power supply (which includes all that use hall-effect current sensors, and some others). For many digital panel meters, however, one of the current sense lines is internally connected to the negative supply for the meter, so if the meter is powered by the 12V system for the RV and no external isolation is provided for the meter's power supply, the shut must be on the negative lead. Sometimes this information is rather buried in their description or documentation.
CA Traveler
The Western States
Posted: 08/27/20 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Good post from DrewE, one size doesn't fit all. Also what is a battery monitor and at what accuracy? A volt meter, a amp meter, Ah or Wh, accumulated power, some time related information, etc.
I would be cautious about installing a shunt near the converter. There may be loads from there to the battery, if not amps will be accurate but volts will be lower due to wiring loss. My full function battery monitor has wires directly from the shunt and + - battery and hence it knows and tracks battery power. From my experience the hall-effect current sensors are not as accurate as the shunt type.
There are lots of options.
I have a $20 "battery monitor" with shunt that displays V, A, W and Wh that I use to monitor the supply for a pricey radio. It only measures current in one direction. With a manual reset it displays Wh and hence the discharge and SOC starting with a fully charged battery.
CA Traveler
The Western States
Posted: 08/27/20 08:51am Link  |  Quote  |  Print  |  Notify Moderator
OP, The negative distribution uses the frame with negative wires connected at various points in the RV. The panel fuses and distributes the positive connection only. There may be a limited negative ground for panel lights, etc. Hence there is no place to install the shunt on the negative lead and near the battery is the best location.
CA Traveler
The Western States
Posted: 08/27/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
This is my battery monitor shunt and disconnect switch. While the house batteries are AGM (with no corroding fumes) there are nearby flooded starting batteries. I spray the shunt and the connections with a battery protector.
