RV.Net Open Roads Forum: Fifth-Wheels: Cold-ish weather camping
 > Cold-ish weather camping
Page of 5
JAC1982
Brighton, CO
Posted: 08/26/20 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
We are headed up to WY in a little over a week and will be boondocking for 5-6 days. The weather forecast is 65-70 during the day, but dropping to 30-32 at night. We have tank heaters available, do we need to use them or should we be OK since it's not prolonged cold weather and we will be using the furnace?
2020 Keystone Montana High Country 294RL
2017 Ford F350 DRW King Ranch
bgum
South Louisiana
Posted: 08/26/20 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
No need to use tank heaters.
JAC1982
Brighton, CO
Posted: 08/26/20 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you! It's our first prolonged boondocking trip with this new rig so just wanted to make sure all ducks are in a row and we come as prepared as we can [emoticon]
jdc1
Rescue, Ca
Posted: 08/26/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
You will need more than one battery or a small generator.....the furnace will eat a single battery a night. Or get a Mr. Buddy Heater.
Near Mammoth, CA
Posted: 08/26/20 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Lows of thirty and up don’t concern me. Considered solar to recharge those batteries?
JAC1982
Brighton, CO
Posted: 08/26/20 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, we have two batteries, a built in generator, and 4 propane tanks (which we can take to refill if needed), so we're good there [emoticon]
We do a lot of boondock camping, just not normally when it dips that cold. We did the same trip last year and it only got down in the mid-40s at the same time.
TXiceman
Full Time RVer
Posted: 08/26/20 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
To get a freezing issue, yo need to be below freezing for a number of hours. Just a quick dip below freezing and back up to 60's during the day, no issues.
Ken
Amateur Radio Operator.
C Schomer
Pueblo West, Co.
Posted: 08/26/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
I've camped near Granby with an uninsulated bottom rv and it got to 15 at night but warmed up quickly in the morning, no problem. 10 degrees at Rubys, by Bryce was a different story... The water lines were frozen til about 11am. Craig
time2roll
Posted: 08/26/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
No need to use tank heaters at 28+ overnight and 50+ during the day.
However if things change and you are dipping into the low 20s consider turning them on. Although the heater take a lot of power and will drain your battery in short order. Would need to run your generator. Possibly just ignore it until you need to dump. In which case dump in the late afternoon to thaw things out.
675w Solar pictures back up
azdryheat
Tucson, AZ
Posted: 08/26/20 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Just pile on he blankets at night and leave the heater off.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Page of 5
