RV.Net Open Roads Forum: General RVing Issues: Water refill when dry camping
 > Water refill when dry camping
EagleScout-USA
Buffalo, NY
Posted: 08/26/20 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
We are finding ourselves camping without water hookups often due to the increase in camping families in our area. After an initial fill at the potable water spigot, we have been "topping off" the freshwater tanks by using 6-gallon potable water jugs and a funnel system. These water jugs are heavy and the funnel-holder member of the family is often getting wet due to splashes. Any suggestions for pumping water from our 6-gallon potable water storage containers into the freshwater holding tank of our RV, as opposed to just dumping it in the traditional way we have? Looked online for liquid transfer system, but finding mostly things rated for automotive fluid transfer and not potable water. Thanks for any suggestions.
MNRon
Tennessee
Posted: 08/26/20 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased a cheap (~$10) drill driven hose pump to use for that situation a few years ago. Can’t say how it works though as we have been able to refill our fresh through hookups or moving and haven’t needed to use it yet.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
ivbinconned
highway 16
Posted: 08/26/20 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.ebay.ca/itm/Sprayer-ATV-25-gal-Tank-Capacity-SAO-H3-025B-MM-/313004681532
We haul in backof truck. Fits in basement so we will also fill it at last stop before boondocking site.
Comes with 12 volt pump. Makes it all easy.
Ram and 34 ft Cedar Creek
Death Valley NP
Posted: 08/26/20 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
X2, Ron.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
ivbinconned
highway 16
Posted: 08/26/20 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like my link doesn’t work. We bought a 25 gal ATV sprayer tank that comes with 12 volt pump that has enough wire to reach the batteries.
bgum
South Louisiana
Posted: 08/26/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Harbor freight 12 volt liquid transfer stick. Very inexpensive. Just but that and several plastic jerry cans. No longer than the water is in it shouldn't make you glow in a dark.
MFL
Midwest
Posted: 08/26/20 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I use a regular 12v RV pump that I replaced years ago, due to it not holding pressure. I can run it from batteries, but normally just use a 12v jump pack. I just put a piece of pex hose on each end, one in 6 gal jug, other in tank fill.
Jerry
mobeewan
Hampton, Va
Posted: 08/26/20 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a spare sure flow pump for the trailer and mounted it to a small cutting board. I attached a 2 pin plug for power and added fittings with hose barbs so I can pump from a container into the water tank fill on the trailer. My winterizing tube is long enough that I can insert it into a water jug and draw from it to supply the trailer using the trailers pump just the same as if it was my water tank. This came in handy when my tank under the trailer started icing up in the wintertime.
Bionic Man
Colorado
Posted: 08/26/20 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
This is what I do. Except since I have a fifth wheel, I use a large transfer tank instead of the 5 gallon jugs.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Lynnmor
Red Lion
Posted: 08/26/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Your trailer has a pump, make some minor changes to the plumbing and use it. On mine, I had a winterizing hose that I connected to the hose behind the city water inlet with a tee, if necessary add a similar hose. I gutted the check valve out of the city water inlet and added an inline check valve inboard of the added tee. I bought an 8 gallon Hydroller portable tank with wheels that I modified with a dip tube, but any tank will work.
No lifting, funnels, wires, switches or battery connections. I can't understand why folks won't use a pump that is already there. A check valve, clamps and a tee were the only purchased items.
