RV.Net Open Roads Forum: Tech Issues: AmeriLite 23BW water tank fix replacement
 > AmeriLite 23BW water tank fix replacement
surgtech56
michigan
Posted: 08/27/20 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced their water tank on a 2011 AmeriLite 23BW. ? We have a leak around the valves picket that goes into the tank.
How do I post a photograph?
* This post was edited 08/27/20 05:18pm by surgtech56 *
MFL
Midwest
Posted: 08/27/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
You might give a little better description of the leak. Is it the actual water tank leaking, or maybe just a hose fitting, from the water inlet? A picture would help, if you can see where the leak is.
Jerry
surgtech56
michigan
Posted: 08/27/20 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
How do I add a photo?
Fisherman
Angus, Ontario, Canada
Posted: 08/27/20 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
Look at the top of the page in red, there's link to the forum photo posting. https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/15775751.cfm
MFL
Midwest
Posted: 08/27/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
google rv.net photo posting: just follow Barneys instructions.
Jerry
surgtech56
michigan
Posted: 08/27/20 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry blurry, it’s been raining. There’s. A leak around this outlet. Any adhesive that will hold s a quick fix? Thank you
mobeewan
Hampton, Va
Posted: 08/27/20 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Is the leak between the fitting and tank or the threads where the drain valve screws into the tank?
Is the fitting cracked and leaking from the threads?
surgtech56
michigan
Posted: 08/28/20 05:15am Link  |  Quote  |  Print  |  Notify Moderator
It looks like both. I thought it was just from the threads but it looks like it’s also leaking between the fitting and the tank. I was going to put a hose clamp on the threads .
Dusty R
Charlotte Michigan 48813
Posted: 08/28/20 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Maybe a "O-ring" like a garden hose gasket.
