RV.Net Open Roads Forum: Class A Motorhomes: Jacks Down Light Stays On
 > Jacks Down Light Stays On
BigDaddy1951
Leesburg, FL
Posted: 08/27/20 07:47am Link  |  Quote  |  Print  |  Notify Moderator
After repairs at Lazydays in the Villages, my Jacks Down light stays on all the time, even with the ignition turned off!! Suggestions appreciated. And don’t say take it back. After my service experience, I wouldn’t let them service my bicycle.
I need to add. 2007 Winnebago Voyage with Level Best Jacks.
midnightsadie
ohio
Posted: 08/27/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I,d be looking for a limet switch, or if this is what they worked on? back to the shop.
crawford
Dandridge Tenn.
Posted: 08/27/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
It really sound like a relay is stuck
Change from a c class to a A class Georgetown 07 triple slide
ct1964ups
Davenport,Fla & Oxford,Ct
Posted: 08/27/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Check the Fluid level in the Pump...C
2017 Newmar Mountain Aire Seville on a Freightliner/2015 Granite Grand Cherokee Limited
2012 American Tradition Merlot>>SOLD
Keep The Rubber On The Road
GO NOLES
enblethen
Moses Lake, WA
Posted: 08/27/20 09:05am Link  |  Quote  |  Print  |  Notify Moderator
What area of the rig was the shop working on? That could be where problem is.
A switch on a jack could be stuck. Inspect and clean switches. Does your control indicate which jack is not completely stored.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BigDaddy1951
Leesburg, FL
Posted: 08/27/20 10:06am Link  |  Quote  |  Print  |  Notify Moderator
The shop was to replace two jacks that were leaking. They took all four off and threw them all away. Then wanted us to pay for all four! Finally after two
months, got it back. Wiring at pump looks like a rats nest and jacks down light stays on NOTE: even with the ignition off and key out. NEVER taking it back to Lazydays!!
enblethen
Moses Lake, WA
Posted: 08/27/20 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you will need to go through the wiring. They must have damaged the power wire and jack wires, or just plane miss wired them.
I did not find much for diagrams for how it is wired.
Only found small info the the yellow wire from the jacks are the switches.
Executive
Posted: 08/27/20 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Well, my friend, you are certainly in a pickle. Here's what I would do. I'd call the service manager, being super respectful, even if meaning you have to bite your tongue and explain your issue. Based on what you've said, finding the issue is going to involve a lengthy search. I'm not sure what your relationship currently is like with Lazydays but I'd certainly try to patch it up. They messed it up, they need to fix it. There isn't an easy fix here as there's no way to determine what was 'fixed', read changed, on your coach during the repairs. So, your wiring/jacks/relays etc. may or may not be as the factory installed them. I had my coach worked on and they bypassed a couple things to get it working again but other things stopped working. It was a mess to trace down the inept work they did. I finally talked to the service manager, set up an appointment and told her I was devoting the entire day or two to getting the coach fixed and I'd be in their waiting room for however long it took. Then I showed up with all my goodies to make myself at home there. I was out in four hours. Best of luck....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
dougrainer
Carrolton, Texas
Posted: 08/27/20 11:46am Link  |  Quote  |  Print  |  Notify Moderator
On your system there should be a Magnetic reed switch on EACH jack. ANY of the 4 jacks that has this switch malfunction will throw the red indicator light. You need to check each jack switch and odds are it will be obvious---wires loose or part of the magnet missing. Doug
enblethen
Moses Lake, WA
Posted: 08/27/20 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Doug:
Why would the light be on with ignition switch off?
