RV.Net Open Roads Forum: Class A Motorhomes: Dimension Inverter/Charger not charging batteries
 > Dimension Inverter/Charger not charging batteries
dvleemin
Edmonton, Canada
Posted: 08/27/20 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I was hoping someone had some ideas on how to resolve an issue I have with my Dimension Inverter/Charger not charging batteries.
Here are the details on the unit:
- 2005 Itasca Horizon 40AD
- Dimension 12x20B3RT Inverter/Charger
Problem:
- when plugged into shore power the batteries are not being charged.
- on the control panel it says: "CHGR-OFF NO INPT" AND "INVERTER-OFF
- the house and coach battery voltage is around 12.7 and shows that it is not charging
- The control unit does show that its on 30 amp
- 120V is available throughout the unit
- running the generator and not connected to short power results in the exact same result
- all fuses on the Dimension, on the chassis, and on the house seem fine
I was able to find the manual for the Dimension but not a lot of help: https://www.rvtechlibrary.com/electrical/dimensions_owners.pdf
I'm guessing some sort of transfer switch type of issue?
Anyone have any ideas on next steps to trouble shoot it?
Thanks,
Darryl
Executive
Posted: 08/27/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Try pushing the on/off button three times and see if the inverter turns itself back on. Also check the internal fuse in the unit itself...Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
ndrorder
Southwest
Posted: 08/27/20 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Here are three things to check.
1. None of the circuit breakers in the main panel at the foot of the bed are tripped.
2. None of the circuit breakers integral to the inverter/charger are tripped.
3. Verify 120V input power to the inverter/charger with a digital voltmeter.
Since you mentioned searching for manuals, I found the Itasca manual at the following link.
http://www.winnebagoind.com/resources/manuals/operatormanuals2005.php
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
CA Traveler
The Western States
Posted: 08/27/20 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Since the message indicates no AC input, what voltage do you read at it's input terminals? If you have done the above and don't know how to safely check then get help.
2014 Grand Cherokee Overland
Bob
dvleemin
Edmonton, Canada
Posted: 08/27/20 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Hitting the reset three times did nothing (didn't change anything on the display either oddly enough).
Confirmed the main fuse is fine.
dvleemin
Edmonton, Canada
Posted: 08/27/20 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Checked all these . . . 120V does even end up at the plugs in the RV.
dvleemin
Edmonton, Canada
Input voltage is right around 120V . . .
time2roll
Posted: 08/27/20 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Could try a full reboot by removing 120v power and disconnecting the battery connection for a few minutes.
My guess, the inverter is shot.
675w Solar pictures back up
Camping near Pearsonville, CA
Posted: 08/27/20 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
2005 converter needs replacement. You’ve been on borrowed time.
