RV.Net Open Roads Forum: Gut check on transfer switch for inverter - special case
 > Gut check on transfer switch for inverter - special case
time2roll
Posted: 08/27/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
I put my converter on a separate breaker to use as a switch.
675w Solar pictures back up
thedavidzoo
Tucson, AZ
Posted: 08/27/20 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone. I have probably beaten this dead horse by now.[emoticon]
2014 Ram 3500 CrewCab Diesel DRW 4x4 4.10 Aisin, Torklift Fastguns, Upper Stableloads, Timbrens
2017 Northstar 12' STC
640W solar, 400Ah lithium LiFeMnPO4 batteries
Z-Peller
Oceanside BC
Posted: 08/27/20 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
A converter uses 110v power to make 12v power and feed it to the batteries. Inverter draws 12v from batteries to make 110v power. You say your converter runs on 12v??...don’t see how.....Check your 110v breaker panel for converter breaker and switch it off. No more converter producing 12v power when you are running inverter for 110v power. There is nothing at converter for 12v wires to backfeed. Wire your inverter thru generator feed which will go to 110v breaker panel then you can turn breakers on or off to select what you circuits you want on or off.
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
DWeikert
York, PA
Posted: 08/28/20 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Hemi Joel wrote:
I didn't think you could run 2 solar charge controllers in parallel? Doesn't one sense the output of the other and interpret that as a fully charged battery, cutting 1/2 your solar array out?
Since the charge controllers monitor battery voltage that would only happen when the battery is fully charged. Or at least one of the controllers thinks it is.
Once the batteries approach full charge the controller set to the highest voltage would be the last one providing current. For example, if controller A is set to 14.38v and controller B is set at 14.42v, controller A would stop providing current at 14.38v then controller B would provide the last bit of charge until the batteries reach 14.42v. But I doubt that's going to be a problem.
Dan
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
12thgenusa
Loveland, Colorado
Posted: 08/28/20 10:19am Link  |  Quote  |  Print  |  Notify Moderator
You are correct in that as you have it drawn there is not a charging loop between the converter and inverter however, powering everything through the inverter is very inefficient and overly complex. You have losses inverting 12V to 120V and then back to 12V through the converter to power the 12V items.
A much better way is to leave the 12V distribution panel connected to the batteries and disconnect the 120V feed to the converter. Another plus is that in the event of an inverter failure all 12V items would still operate.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar,
Rogue MPT-3024, 440 AH GC2 bank, ProWatt 2000,100% LED lighting
thedavidzoo
Tucson, AZ
Posted: 08/28/20 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, this is now the plan!
2oldman
New Mexico
Posted: 08/30/20 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see that.
computermonkey
Oklahoma
Posted: 08/31/20 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Example of what I did. I wanted to power every 110v socket through the inverter. I added a second transfer switch making the inverter dominant, that way power from the first transfer switch would be on all the time until inverter was turned on then twenty seconds later the transfer switch would allow the power from the inverter.
I have two circuits coming off the battery. One is a 100amp BMS. The camper's 12v power and charging is done through this. Also has temp cut off so if to cold it will stop the charging from damaging the batteries. Second is a 250amp using 4/0 wire going to a 3000watt inverter with a low volage battery disconnect.
I set the refrig to propane and unplug the converter. Charging is done mostly there solar.
https://imgur.com/oO1xBRL
https://imgur.com/EK2CX1x
https://imgur.com/wKBA2SG
New
2013 RAM Crew Cab, 3500 4x4
2019 Arctic Fox 1140 wet bath
Old
2016 Eagle Cap 960
2004 Jayco Talon ZX
1998 GMC Suburban with a Cummins 6BT conversion.
