RV.Net Open Roads Forum: How often and how to clean black tank
 > How often and how to clean black tank
jdc1
Rescue, Ca
Posted: 08/27/20 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Biodecomposition? LOL. It's not a septic tank with a leach line. If it smells, you got problems. The water in the toilet should stop all odors from coming in.
I flush my tank every time I get back from a trip. It takes 3 minutes using a Flush King.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 08/27/20 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
I've never cleaned the black tank in my trailer or DP. After you empty it, put several gallons of water in it which will get swished around, don't empty it. Things don't bio-degrade in a black tank, it is not a septic system.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
pbeverly
South Carolina
Posted: 08/28/20 05:02am Link  |  Quote  |  Print  |  Notify Moderator
I take a 5 gallon water tote that I use for coffee, ice and drinking water. At end of trip when I dump whatever is left in toe is dumped into toilet for swishing as I drive home. That is drained, run water thru flush system for a few minutes. Black and Grey tanks with water adding Tank Blaster which is cheap on Amazon. It works for me. I will let they sit for at least 24 hours and then dump. Water ends up coming out clean. I also park RV where I can dump in this manner.
Ridgeway, SC
Tvov
CT
Posted: 08/28/20 05:25am Link  |  Quote  |  Print  |  Notify Moderator
rvshrinker wrote:
We have sani flushed the tank only once in 3 years. Recently I read I should be doing this more often. On the other hand some places say not to empty black too often because then there is an inadequate amount to drive biodecomposition. It does smell now despite minimal use so I'm planning to flush.
Also I read to 1. Empty tanks. 2. Fill with some toilet flushes. 3. Add some bleach and dish soap. 4. Let sit. 5. Empty. 6. Leave black tank open. 7. Flush for a while (how long?). 8. Close up. 9. Flush some water into toilet.
We use the rv for 3-6 4-16 day trips per year. And occasionally at home as a spare bedroom or office. In The latter cases, if it makes sense to avoid using the toilet we could easily do this.
I drain and flush the black tank on our TT after every trip. Then I fill the black tank with water and a big dollop (1/2 - 1 cup) of bleach, let it sit about an hour, then drain it again.
We go weeks or months between trips, so the camper is just sitting. If the black tank isn't thoroughly rinsed out and sanitized it will stink up the camper.
We used to camp a lot with 2 other families, brothers, who own a septic / excavation company. When they bought new campers, they insisted that people were wasting their time flushing black tanks, as they were experts and knew that the "stuff" in the black tank would biodegrade and not smell. I just shrugged my shoulders.
Next camping trip they said that their shop where they store their campers stank to high heaven, and they sheepishly said "yea, the campers don't have septic tanks but holding tanks that need to be cleaned".
2008 F-250 CrewCab 5.4L,
lots2seeinmyrv
Neither Here nor There
Posted: 08/28/20 06:33am Link  |  Quote  |  Print  |  Notify Moderator
After camping, before heading home, we drain the tank. Fill with water to rinse out and empty the tank.
Hooking up for the next trip we put 3 buckets of water in the black tank. We add one cup liquid Calgon water softener and one cup 20 Mule Team Borax.
We let that slosh around on the drive to the campground.
We dump that when we get to camp. Then fill the black with a couple buckets of water and use the commode.
Repeat the same process. Never had any issues.
dodge guy
Bartlett IL
Posted: 08/28/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
All of my RV`s have had a black tank flusher. I have used it after every dump. we almost always have FHU`s. once in a while I`ll have to use the dump station. if there is no one in line I`ll flush it like always, otherwise it just gets a quick flush. No smells in 16 years.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
rvshrinker
Beautiful Pacific Northwest
Posted: 08/28/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the info and ideas. I can dump at home, which is convenient, but means I don't empty before leaving camp and therefore don't rinse on the drive home. We often don't have a dump at camp anyway. I think I'll just empty and rinse and maybe try some soap and bleach and water again and see what happens. Doesn't sound like I can hurt it.
way2roll
Wilmington NC
Posted: 08/28/20 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Adding bleach to your holding tank means eventually you will be dumping that bleach into a septic system and effectively killing a lot of bacteria that are needed in an actual septic system.
Water, water, water. A holding tank is not a septic system and so there is no need to maintain any level of bacteria. Make sure you use enough water while camped and keep a layer of water in the tank after you've dumped and flushed. Your RV holding tanks are a temporary place to store waste until you can dump - that's it. If your unit does not have a black tank flush, install one. I have a clear elbow on my dump line and after I empty grey, then black, I flush the tank (run the tank flush, close the valve let it fill a bit, dump repeat) until things run clear, then add a little water and close up. Granted this may not be practical in the line at the dump station, but if no line then no problem, otherwise I do it the next time I can.
2 things that will cause smell - not using enough water while camping (can end in the dreaded poo pyramid) or leaving it too dry after you dumped.
2020 FR Cedar Ridge Silverback 29rw
bigorange
Tucson, AZ
Posted: 08/28/20 07:49am Link  |  Quote  |  Print  |  Notify Moderator
If you can dump at home, just give it a good flush after you dump since nobody is waiting in line. We have a dump station at storage so there’s rarely anyone waiting...I dump the black then close the valve and turn on the hose to the flush for a minute or two...then dump again. Repeat as necessary based on what’s coming out the hose. Use the flush again to add a little water back into the tank for storage.
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
C.B.
APPLETON WI USA
Posted: 08/28/20 08:19am Link  |  Quote  |  Print  |  Notify Moderator
After reading about the geo method for days I decide to clean my tanks for the first time. This morning I treated both gray tanks with 1 cup of Zep Heavy Duty Citrus Degreaser in 5 gallons of water.
The black tank I used 1 cup of Borax (had a hard time finding,couldn't find Calgon in any local stores) and 1 cup of Cascade dish washer soap to 5 gallons of water. Will be traveling about 45 miles today. Will be dumping tanks on Sunday.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
