RV.Net Open Roads Forum: How often and how to clean black tank
 > How often and how to clean black tank
Tvov
CT
Posted: 09/01/20 05:29am Link  |  Quote  |  Print  |  Notify Moderator
spoon059 wrote:
Tvov wrote:
I don't think it is just my camper or my diet... many friends with campers have said that if their tanks aren't thoroughly rinsed, their campers will smell after sitting in storage or just sitting unused for extended periods.
Try dumping your black tank, but don't rinse it or use toilet chemicals afterwards. Let your camper sit unused for months.
I would be impressed and surprised if your camper doesn't end up getting that "black tank smell". May not be over whelming, but it is there.
If you can store your camper without rinsing the black tank, and have no smells after an extended period, keep doing whatever it is you are doing!
It is possible we are thinking of the same thing, but using different terminology.
For 10 years I've rinsed and left water in the bowl, never had any sewer smells in my camper. One year my wife was pregnant and very sick, we didn't camp at all that summer. No special arrangements made and zero sewer smell in my camper. Clean it properly and maintain it properly and it will not smell. Fail to either clean it or maintain it and it will smell. You can fill the tank full of bleach to mitigate other problems, but it won't solve those other problems.
If you have to sanitize your black tank (literally, clean it to make it sanitary, thus no traces of human waste) to prevent smell then you have something else going on. The systems are designed to hold human waste and not smell inside the camper. If your camper is leaking sewer odors into your camper, it is potentially dangerous and clearly not working as designed. You should look at getting that fixed, rather than masking it with sanitizers.
Okay, so you DO rinse your black tank. Yes, a properly cleaned out black tank does not smell.
I go an extra step and sanitize the tank when we aren't going to be using it for an extended time.
As far as I am aware, our camper and its tanks are fine and in proper working order, same as my friends that have similar issues when they don't clean out their black tank.
We are just talking in circles now - so keep taking care of your camper the way that works for you, I will take care of mine the way that works for me.
Maybe we'll meet at a campground somewhere!
2008 F-250 CrewCab 5.4L,
frankwp
Calgary, AB, Canada
Posted: 09/02/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
rvshrinker wrote:
3. Add some bleach
That is generally a bad idea. If the dump station or campground uses a septic system, the bleach will mess up the decomposition process.
As mentioned, a clear elbow is essential to the process because you need to know the state of what's coming out of the tank. We always camp with full hookups & only rarely use dump stations.
This is my routine:
- When the tank needs dumping, I turn on the sani-flush for about 30 seconds to "stir the soup", then open the dump valve. The sani-flush stays on for the duration of the dump.
- When the water is coming out clear, the dump valve is closed. The sani-flush then serves to put water back in the empty tank. I have one of those garden hose water meters & it lets me know when I have about 5 gallons in the tank.
- When breaking camp, I do the dump, but I'll put about 15 - 20 gallons back in, then dump again. Then I'll fill the tank with about 20 gallons and 1-1/2 cups of HE (low suds) laundry detergent. That mix stays in there until I get to a dump station that is close to home and completely drain it, put in 5 - 10 gallons, and completely drain it if it's the end of the season. If not, 5 gallons goes back in.
It's amazing how much gunk gets cleaned out by the detergent and the agitation of driving down the road for a couple of hours. I also give the galley tank the same treatment at the end of each system. I don't use any other tank chemicals.
The final dump of the season takes 10 - 15 minutes, so I do it at a dump station close to home where it costs me $10 to dump & I don't have to feel bad about taking my time.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
spoon059
Just north of D.C.
Posted: 09/03/20 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Yes, hence ;
spoon059 wrote:
If I have a full hookup site I will hook up my black tank flush and flush for a couple minutes every trip. If I am at the dump station and there isn't a backup, I will flush for a couple minutes as well. I'm probably doing it excessively, but its worked for me.
I usually keep the black tank flush on while dumping the black tank to help move along the solids, then I'll close the black tank for 2 or 3 minutes to build up the water level in the tank, then open the black tank again. That "surge" of water coming out helps to clean up most of the solids. Then I make sure to leave a couple gallons in the tank after I close the black valve again.
Sanitizing your poop tank is wasting money and resources. That was my point. Hope to see you out there some time!
2015 Ram CTD
2015 Jayco 29QBS
austinjenna
Columbus, Ohio
Posted: 09/04/20 05:23am Link  |  Quote  |  Print  |  Notify Moderator
I do the same thing as you. If there is a line at the dump station I will just dump then flush back at my storage lot.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
way2roll
Wilmington NC
Posted: 09/04/20 06:42am Link  |  Quote  |  Print  |  Notify Moderator
X3 - same process I use.
2020 FR Cedar Ridge Silverback 29rw
pigman1
Delaware
Posted: 09/04/20 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Yep, that's the procedure. Works all the time, every time.
I know the following is going to blow some of the "rules" folks minds, but... We do a lot of traveling and boondocking. I've plumbed the black tank rinse system directly into the coach's fresh water system, on the pressure side of the pump. We have two shutoff valves in that connecting line, and the system back flow preventer. This gives me a few things I ordinarily would not have. I don't need a separate black tank flush hose, I don't have to deal with a black tank hose at the flush site that someone has shoved up his sewer hose to "clean it out" and, if necessary I have a garden hose connection in that line that I can use to clean sections of the outside of the coach if I've been in VERY dirty or muddy conditions. Like the Top of the World Highway in Alaska or other unpaved places. Of course we have to be careful with fresh water tank levels, but for us this procedure has been working for over 110,000 miles in the 2013 Bus and for over 50,000 miles in the former 2008 Bus. Against the "plumbing rules"?? Of course, But it works and I'm not risking anyone but me.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
kellem
Shenandoah valley,VA
Posted: 09/06/20 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I understand the craftiness and convenience this may have provided but also a significant decrease in water pressure when flushing the black tank.
But some flush is better than no flush.
K3WE
Missouri
Posted: 09/09/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
“then there is an inadequate amount to drive biodecomposition.”
RVs have holding tanks. While breaking up “chunks” for easy dumping is a good thing RV tanks are not made for decomposing.
I have always wondered, are there signs in there that tell the ever-present microbes to NOT do what they normally do?
way2roll
Wilmington NC
Posted: 09/09/20 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
It's not in there long enough to decompose - at least it shouldn't be in there that long. It's a holding tank not a septic tank. Sure the microbes exist - unless you add bleach.
Atlee
Mechanicsville, VA
Posted: 09/10/20 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I laughed and grimaced at that image. [emoticon] [emoticon]
Lynnmor wrote:
A clear elbow at the drain connection will tell you all that you need to know. Drain and flush often till the brown trout are no longer swimming downstream.
Erroll, Mary, Duffy the Dachshund (RIP)
2018 Jayco Redhawk 22J
2017 Jayco Jay Flight 23RB
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
And Blue Ox WDH/Sway Control
