jimcatinmi
michigan
Hope this is the right place for this. What does everyone else do with their hitch in the winter? Is it ok to leave it mounted in the bed? we do have a soft cover on the truck to keep the snow off but not sure what to do for the winter. We live in Michigan so we do get snow and cold. T
2014 F150 5.0 coyote
Flowmaster Cat back
2006 Laredo 29RK
Pullrite superglide 16k
Monroe Load Assist
ACZL
UPstate,NY
I take mine out and replace it w/ 1200# of tube sand
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
austinjenna
Columbus, Ohio
Mine stays in the bed and I also have a hard top roll cover on it
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
Jim&Sharon
Arnold MD
Sure, you can leave it in the truck bed. Exposed to the weather, not being used, in the way of other loads.
I hang mine from the 5th wheel king pin. Put it back in the truck in the spring.
2006 Wildcat 27RL
2006 2500HD w/Allison/Duramax
KB3TXH
valhalla360
No paticular place.
As long as you don't need the bed for other uses, certainly, you can leave it in.
An easy alternative is to pull the pins holding it down while still hooked up and then when you lift the front of the 5er, it will take the hitch with it (do make sure the latch is locked so someone doesn't come by and pull the latch having it drop on them)
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
jimcatinmi
michigan
Jim&Sharon wrote: Sure, you can leave it in the truck bed. Exposed to the weather, not being used, in the way of other loads.
This is just my T/V have another truck if I need to haul something was just trying to figure out what others did with the hitch for the winter not looming for advice on how to haul something else.......but thanks
Second Chance
Wherever...
You have to be careful doing this with certain hitches. On the PullRite hitches, the latch arm under the fifth wheel plate can be damaged if too much upward force is applied by the king pin. On many other hitches it's no problem.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
RCMAN46
NorthWest
Second Chance wrote: Jim&Sharon wrote: Sure, you can leave it in the truck bed. Exposed to the weather, not being used, in the way of other loads.
Rob
"Damage if there is an upward force by the king pin". Explain how that hitch can work when you hit a chuck hole or go over a rough railroad crossing!
JIMNLIN
Oklahoma
Mine hangs with a old come a long in the tractor shed from two eye bolts in the top plate, when not in use. I keep a cooker cover over it with velcro on the open end to keep mud daubers/wasps out.
If you leave it hanging from the hitch jaws be sure and pad lock it closed. One member of a brand specific forum left his hanging. Kids messing with it probably pulled on the lever, he thought, and drop on one breaking his ankle.
frankwp
Calgary, AB, Canada
Second Chance wrote: You have to be careful doing this with certain hitches. On the PullRite hitches, the latch arm under the fifth wheel plate can be damaged if too much upward force is applied by the king pin. On many other hitches it's no problem.
Rob
If hanging the hitch from the king pin damages it, then that hitch should never be used for towing.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
