RV.Net Open Roads Forum: Fifth-Wheels: What to do with my hitch
 > What to do with my hitch
BB_TX
McKinney, Texas
Posted: 08/28/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
frankwp wrote:
Second Chance wrote:
You have to be careful doing this with certain hitches. On the PullRite hitches, the latch arm under the fifth wheel plate can be damaged if too much upward force is applied by the king pin. On many other hitches it's no problem.
Rob
If hanging the hitch from the king pin damages it, then that hitch should never be used for towing.
I don’t know the answer, but hitch jaws hanging from the pin is a completely different force than the 5er sitting on the large flat hitch plate. The first the weight is concentrated on moveable parts of the hitch latching mechanism. The second the weight is sitting on a flat steel plate.
* This post was edited 08/28/20 06:19pm by BB_TX *
Durb
NW
Posted: 08/28/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I lift mine out of my bed with the trailer then lower it on to a hydraulic table. I roll it into the garage and throw a sheet over it. After six seasons, the hitch is still in excellent condition. Even with a roll top cover a hitch will condense moisture on its surface.
Campinfan
Washtenaw County, Michigan
Posted: 08/28/20 09:31am Link  |  Quote  |  Print  |  Notify Moderator
I leave mine in all the time. I figure in the winter, I need the added weight back there. Mine is really heavy plus then I would have to find a place to store it.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
schlep1967
Harrisburg, PA
Posted: 08/28/20 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Perform seasonal maintenance on it. Make sure everything is lubed. Cover the bed and enjoy the winter.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Allworth
Orlando, FL
Posted: 08/28/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Ten years of hanging from the king pin hasn't hurt mine.
They is tuff little suckers!
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
JAC1982
Colorado
Posted: 08/28/20 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
We leave ours in these days as we only use the big truck for towing. It has a bed cover on it. But, in years past, we've taken it out and set it on one of those cheap furniture dollies from Harbor Freight so we can move it around the garage easily if needed.
2020 Keystone Montana High Country 294RL
2017 Ford F350 DRW King Ranch
2021 Ford F350 SRW Lariat Tremor
Njmurvin
Simi Valley
Posted: 08/28/20 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
When I had my Superglide, I used a HF hoist to lift it out of the bed and lower onto a metal rolling cart, cover it with a patio furniture cover and store it under the fiver overhang. Now that I have the Andersen Ultimate, I just lift it out and set it on the same cart, cover and store the same way. That said, I'm in SoCal and don't have to deal with severe weather (unless you count fires and drought).
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
cougar28
Lowell,AR USA
Posted: 08/28/20 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Take mine out every year. I use my tractor with pallet forks. I put the hitch on the pallet and put it under the 5er overhang while the 5er is in storage building.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
bobsallyh
Livingston, TX.
Posted: 08/28/20 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
My whole hitch assembly including the head, Pullrite, has remained in the dually bed for 17 years.
RCMAN46
NorthWest
Posted: 08/28/20 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
I find it interesting that B&W makes a device that is used to remove a 5th wheel hitch that takes the place of the king pin.
B&W BWRVXA3130
[image]Click For Full-Size Image.
