RV.Net Open Roads Forum: Fifth-Wheels: Weight of air vs. Nitrogen
 > Weight of air vs. Nitrogen
Campinfan
Washtenaw County, Michigan
Posted: 08/28/20 11:06am Link  |  Quote  |  Print  |  Notify Moderator
So I made an amazing discovery today. I got my new Sailuns partially installed today (so far). When I took the old tires and rims to Discount Tire, they were easy to lift and move into my truck. When I picked up the new Sailuns they were really heavy. Same rims. The old had nitrogen and the new has plain old air. So it must be the air.
Sure it has nothing to do with going from an F rated tire to a G rated. [emoticon]
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
12th Man Fan
Flower Mound , Texas
Posted: 08/28/20 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Be sure to check the pressure in the new tires. When I had DT mount my new tires they said they could only put 80psi in the tires because of their euip.
Good thing I asked.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Old-Biscuit
Verde Valley
Posted: 08/28/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Atom for Atom, Nitrogen is Lighter than Air
Nitrogen has an Atomic Weight just over 14 & Oxygen has an Atomic Weight of almost 16
Air,,,,mixture of Oxygen & Nitrogen will be 'heavier' then Nitrogen
Air,,,,78%-Nitrogen, 21%-Oxygen, 1%-Argon, water vapor/trace elements
So your hypothesis is correct......air filled tires are heavier then nitrogen fill ones
Course size/heft of an 'F' rated tire VS size/heft of a 'G' rated tire throws a monkey wrench in the whole concept
LOL......
US NAVY------USS Decatur DDG31
Lynnmor
Red Lion
Posted: 08/28/20 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Here is one example of the massive loss of weight:
The weight difference between oxygen and nitrogen is less than 3%, but let’s take the full 3%.
One 255/40/17 summer tire holds approximately 13.88 liters (0.5 cu.ft.) of air at 2 bar (29.4 psi).
One liter of air is roughly equal to 1 gram so there are roughly 13.88 grams of air per tire, 55.52 grams in all 4 tires. Nitrogen is 3% lighter than oxygen, but there’s only 22% oxygen in air, so the difference in weight from all 4 tires is 0.3664 grams, that’s a whopping one third of a gram!
Here’s the math: 55.52 gr x 0.03 x 0.22 = 0.3664 gr
To put it in perspective, one official ping pong ball weighs 2.7 grams.
Hammerboy
Zeeland, MI
Posted: 08/28/20 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Reminds me of a funny story I heard once from a factory maintenance foreman I knew. He told a young apprentice once to get dolly because they needed to bring a small portable air tank to a location and the tank had 150 pounds of air inside. Apprentice fell for it and got the dolly.[emoticon]
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
jdc1
Rescue, Ca
Posted: 08/28/20 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Dan
Wonder what the kid would have done if it was a scuba tank with 2,500 psi?
delwhjr
TX
Posted: 08/28/20 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
He would have brought the forklift, of course!! [emoticon][emoticon]
2019 F250 Crew 4x4 6.2
2019 Rockwood UltraLite 2608BSD
Martyn
Panama City Beach, FL USA
Posted: 08/28/20 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
It could also be because there is more tread on the new ones! [emoticon]
2020 Keystone Cougar Half-Ton 27SGS;
2019 Dodge Ram 2500 QC 4x4 6.4l BigHorn;
Pullright Superglde; Rotochoks; 2 Honda EU2000i's;
Our Website
agesilaus
North Florida
Posted: 08/28/20 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
LOL......
OK some real numbers the molecular weight of air is about 29 g/mole, the weight of nitrogen gas (remember is is N2 and O2 not N and O) is 28 g/mole. 28/29 is about .965 some you save a whopping 4.5% of the weight of the gas. My educated guess is that there is only 3 or 4 moles of gas in a tire, probably less. And so you save 4 grams of weight and it takes about 30 grams to make one ounce.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
JesLookin
Appleton,WI
Posted: 08/28/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Probably went from 80 to 100 psi
2013 Arctic Fox 27-5L
2014 Ram 3500 6.7L CTD, Crew Cab
