RV.Net Open Roads Forum: Fifth-Wheels: Hauling generator on upcoming trip
 > Hauling generator on upcoming trip
Chinolbz
Lake Havasu City, AZ
Posted: 08/28/20 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you like frequent chats with the local LEO's I would relocate the license plate to the rear facing side of the generator. Buddy got a ticket a couple of weeks ago! Chino
valhalla360
No paticular place.
Posted: 08/29/20 05:25am Link  |  Quote  |  Print  |  Notify Moderator
If it's in the bed behind the hitch, as long as you point the exhaust away from the sides, you can run it in the truck bed.
Alternatively, it's fairly simple to build a rack on the pin box of the trailer. That's about the most stable position you can find and doesn't conflict with anything.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
PhilipB
MO
Posted: 08/29/20 07:31am Link  |  Quote  |  Print  |  Notify Moderator
We've done both. In bed and on the back like Padredw. We had a 3000 Yamaha so very similar weight.
Our hitch on the back cracked and sagged first time out. Luckily we caught this. WE reinforced the hitch, but never did this again.
Back of truck bed has worked well. Typically would unhook truck from 5er when running genny.
New rig is a TH so it's built in.
2015 Ram 2500
2013 Raptor 310TS
GMH
Canada
Posted: 08/29/20 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I mounted a set of wheels on my generator and made a couple of ramps from 2x8’s. It is very easy to push it up into the truck now. There is room in front of the hitch up against the cab. I have run it right from there (with an extension cord) and also unloaded it at a campsite.
padredw
East Texas
Posted: 08/29/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I like the ramps. This generator is a two person job.
Also note: I do have a cover and use it, just removed for the photo.
pianotuna
Regina, SK, Canada
Posted: 08/29/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
I added a 2nd receiver and had a cage built for the generator.
I used a rack similar to the one in the previous posts for ten years. The 2 inch receiver had a much higher rating than 350 lbs.
Regards, Don
ivbinconned
highway 16
Posted: 09/05/20 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a “transfer switch “ to facilitate our gen in front storage space. This is also location of inverter so we have two options up front.
Ram and 34 ft Cedar Creek
ivbinconned
highway 16
Posted: 09/05/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
https://forums.trailerlife.com/index.cfm/fuseaction/thread/tid/29746971.cfm
dccamper
North Carolina
Posted: 09/05/20 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
I went the route on the safety struts and generator carrier tray from this company. About 15000 miles no issues.
https://mount-n-lock.com/all-products-category?sort=p.model&order=ASC&limit=100
Edd505
Elephant Butte, NM
Posted: 09/05/20 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
just short of 4 years on the LCI rack, I have a 30amp cord that reaches in place.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
