RV.Net Open Roads Forum: Truck Campers: Inverter installation question
 > Inverter installation question
Page of 6
mattyj
Long Island.New York
Posted: 08/29/20 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
I was recently at the beach on a rainy day in the morning and my wife wanted a cup of coffee I had to run out and start the generator in the sand and rain that's the only reason I want an inverter. LOL
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs and Stable Loads 2004 Lancelite 835 ,a/c ,electric jacks , conveince/all weather packages
2oldman
south
Posted: 08/29/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
That's a good reason.
The 600w draw is a little better, that's 50 amps. Now we're getting into 'maybe' territory, depending on how long the coffee takes. Get ready for people to tell you how else to make coffee. I myself will not.
It's possible a lithium battery could do this, but it'll cost you.
mattyj
Posted: 08/29/20 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Last year I spend $400 on this life line deep cycle battery I can't afford another battery, as for the coffee I guess I could use instant which would be fine with me but not with her LOL
mattyj
Posted: 08/29/20 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
rtk2
Alberta
Posted: 08/29/20 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Group 27RV battery is about 100 Ah. Times 12 volts = 1200 watt-hrs. 50% usable capacity reduces the available energy to 600 watt-hrs. So in a perfect world with a fully charged battery and no other loads, it will supply 600 watts for one hour, assuming 100% efficient inverter. Most cheap inverters are about 75-80% efficient.
jdc1
Rescue, Ca
Posted: 08/29/20 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
mattyj wrote:
Sorry I should have been more specific I will only use 1000 watt inverter to power a 600 watt coffee maker, I won't even bother with the mv.
Get a French Press....or a generator. One battery will not suffice for a coffee maker, microwave, blow dryer, or electric heater. They all use a ton of power.
mattyj
Posted: 08/29/20 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I guess an inverter is not in my future, thanks everyone for your input and help, coffee press never heard of it sounds interesting I will look into it thanks Lou
jaycocreek
Idaho
Posted: 08/29/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of people run the small coffee makers on power stations like the Yetti and Jackery 1000 watt hours....It works fine...They have built in 1000 watt Pure Sine wave inverters..I don't see why a group 27 battery with more amp hours wouldn't work...
They also run the small Instapot off of them...I'm buying a small coffee maker which users 650 watts for the same reason you did...
1994 F-350 DRW /460/k&n intake /415# torque/lance 9.6/Engel compressor fridge/3 gr 27 batteries/Honda 2k/Honda 3K/WH Camo 2250/Reese solid bar extension/Buddy heater/3 inverters//Happi Jack tie downs /Firestone bags/Yamaha Rhino/Winch and Lockers
Kayteg1
California > Nevada
Posted: 08/29/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I've been using and abusing inverters for decades on different vehicles and assuming you have 100 Ah battery, you might power 1000 w microwave out of it for couple of minutes.
Too many variables to be specific, but first thing to check is to make sure inverter has good cooling flow. With power close to max output, it could overheat faster than battery will drop the voltage to cut it off. Length of cables will play role as long cable will create higher voltage drop.
Over the years I managed to get 800W coffee maker and 800W toaster.
Even you could calculate that running 1200 coffee maker for 6 minutes and 800W 9 minutes takes the same energy -inverters tend to work much better at lower power draw.
Beware that at high load - the voltage will drop below 110V, so heating time will need to be extended.
My favorite experience was using 1200W inverter to run 1500W oven on my boat with 30 amp alternator and 60 Ah battery.
When I used oven only with engine on, it would routinely cut off after 7 minutes, what was due to overheating.
Boat had good cooling and San Francisco Bay is never really warm, yet overheating still was main problem.
The 30 amp charging breaker never flip.
jaycocreek
Idaho
Posted: 08/29/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
From the article on coffee makers..
I’m going to assume that you live in a travel trailer, van, or RV and have some way to get power in the morning. For me, I use my goal zero or my inverter generator to power my coffee maker. Because the amount of watts each of these puts out is limited I have a small coffee maker that doesn’t use more than 625 watts while brewing.
If you don’t have a way to get power, pour-over coffee makers are a great way to go. I have one as a back up that I use some mornings when my battery is empty or I don’t want to start up the generator. If you live in an RV, van, or car there are even 12-volt options for making coffee.
Now to the question. What coffee maker should I buy for my RV? It should be small for easy storage, and energy-efficient. All the coffee makers on my list can be run with a good quality 1000 watt generator or a Goal Zero Yeti 1000.
Page of 6
