RV.Net Open Roads Forum: Beginning RVing: Selecting portable compressor
 > Selecting portable compressor
wanderingbob
monticeeo, fla
Posted: 09/03/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I also advocate for 110 volt compressor as said by "bpounds " but , I never would run a compressor on an extension cord . You can move air thru a hose with out increasing the amps needed , unless the extension cord was at least # 12 ga .
JimK-NY
NY
Posted: 09/03/20 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
I cannot imagine bringing a 110 volt compressor for RV use. I rarely camp with hook ups and I would want to be able to deal with a tire out on the road.
Ten years ago I bought a cheapie, Slime compressor from Walmart. It was about $35 and the equivalent units are not much more expensive now. I have used it a great many times. It is slow if you need to pump up a tire that has leaked. I use it mainly for adjusting tire pressure over time or due to temperature changes. In addition to being cheap it takes up very little space.
austinjenna
Columbus, Ohio
Posted: 09/04/20 05:20am Link  |  Quote  |  Print  |  Notify Moderator
I had bought a portable 12v one named Truckair that goes to 150psi that I have had for years and works great. I use it for the tires, pinbox and hitch
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
rhagfo
Portland, OR
Posted: 09/04/20 06:22am Link  |  Quote  |  Print  |  Notify Moderator
Well the great thing about the on board Viair on my TV, is that as stated before it will operate my impact wrench with it's 2.5 gallon tank. so I could loosen a stubborn lug nut if needed.
JimK-NY
NY
Posted: 09/04/20 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Or for about $15 you can buy a 2' breaker bar from Harbor Freight. That way you would not need a large compressor, electrical hookups, a 2.5 gallon tank and the impact wrench.
Especially for RV use, I always look for the low tech, low cost solution. Actually I try to avoid changing my RV tires. I spend roughly $150/yr for Premier AAA coverage. I only had one flat and the AAA driver had to make a 150 mile trip in each direction. Fortunately we were already at a campground so the 3 hr wait made no difference.
