RV.Net Open Roads Forum: Towing: Tow/haul mode
Search only in Towing
Open Roads Forum  >  Towing
 > Tow/haul mode
jimbo4UT
Stafford Virginia
Posted: 08/30/20 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
What to do? I was on a steep grade and tapped my brake and it downshifted from 3 to 2 and hit 6000 rpm. I still wanted to slow down more but could not hit the brake again as I was high on rpm already in second so I took it out of tow mode and hit the brakes hard then put it back into tow mode. Was that correct? What would have happened if I hit the brake in tow/haul mode from second to first gear with no room for more engine rpm?
Jim
Camping near Pearsonville, CA
Posted: 08/30/20 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
“but could not hit the brake again as I was high on rpm already” What?
Leave in tow/haul mode. Don’t overthink. Use your brakes as required...slow way down, release brakes to cool, repeat. Read an article on downhill driving.
Fisherman
Angus, Ontario, Canada
Posted: 08/30/20 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Have you read your manual?
Posted: 08/30/20 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
I’ll bet not, fisherman.
Second Chance
Wherever...
Posted: 08/30/20 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
What tow vehicle? Is it diesel or gas? What kind of load are you towing? Give us something to go on, here...
I my case going down a steep grade, with a diesel and a six-speed transmission, I put the transmission in "Manual" mode and select the gear I want. I can then tap the brakes as needed to supplement the engine brake.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 08/30/20 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
If the TV is anything newer the computer should protect the motor from you. So no it shouldn't down shift again unless you have a 10K redline.
Sounds like you need more TV or less Trailer and to slow down before going down long grades.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Nodaker
North Dakota
Posted: 08/30/20 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming the transmission and engine are working properly together, you can step on the brakes again to further slow down. It won't down-shift again into 1st until you're going slow enough to not exceed allowable rpm's.
Nodaker
2010 Jayco Melbourne 29D
2011 Chev Colorado dinghy
KD4UPL
Swoope, VA
Posted: 08/30/20 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
You were not correct. Leave it in T/H. Most vehicles I've driven (Chevys) won't downshift to 1st. No matter the vehicle the computers will protect it from over reving. Putting the brakes on further will not cause a downshift to "destroy the engine" rpm.
If I'm on a road I know I like to just use manual mode because I know what gear I need to be in for which hill. On a new route, just leave in T/H and apply brakes as necessary.
kellem
Shenandoah valley,VA
Posted: 08/30/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your dealing with a subpar tow vehicle struggling to slow the mass, honestly.
20 years towing in tow-mode and not seen those RPMS.
Perhaps a manual downshift to mitigate excessive racing of the engine.
JIMNLIN
Oklahoma
Posted: 08/30/20 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Tow/haul mode works in many different ways depending on vehicle brand/which tranny/which engine and a host of other criteria.
Need more input for a accurate shot of how your tranny can work.
 > Tow/haul mode
