RV.Net Open Roads Forum: Truck Campers: bigfoot on shortbed srw
 > bigfoot on shortbed srw
sftcamper
santa fe nm
Posted: 08/31/20 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have a bigfoot25c9.6sb on a ram 3500 diesel crew cab shortbed srw? Would like to know how it rides and what suspension changes might be needed.
Bert the Welder
Van. Island
Posted: 08/31/20 10:05am Link  |  Quote  |  Print  |  Notify Moderator
https://www.truckcampermagazine.com/buyers-guide/hard-side/bigfoot-camper-buyers-guide/
Could probably add a couple hundred more to the "Stuff" weight, depending on your needs. Plus add people and pets.
Your truck year and build packages will factor into what your truck can take.
Whether you want to be driving with that much on an SRW as appose to the extra safety of extra wheels and capacity of a DRW........that will get you into a long, deep debate swamp on here. [emoticon]
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
bigfootford
Fair Oaks, California
Posted: 08/31/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
The 9.6 BF is not built with enough fiberglass frame structure to support that much weight hanging over the rear of a short bed truck. Also center of gravity would actually reduce front axle weight. My 9.6 only puts 300lbs on the front axle..
I have a friend that has an older BF that is 11'5". Even on a long bed the rear of the camper has sagged quite a bit and caused a delamination of the internal structure of the walls at the rear overhang. He fixed that but the sag was not much better.
My 9'6" does sag just a bit back there too and that is on a long bed. No structure problems though... 20 years, lots of miles and many rough roads! All the way to Prudhoe bay and more.
Lastly... Both the gray and black tanks are in the overhang... 50 gallons when full. Along with that part of the fresh water tank is in that last 1.5' of overhang... A short bed would place about another 2' of water weight in the short bed overhang of the camper.
The 9.6 holds about 50 gallons of fresh water...
Jim
* This post was edited 09/01/20 10:35am by bigfootford *
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
Posted: 08/31/20 11:44am Link  |  Quote  |  Print  |  Notify Moderator
^So you’re saying Bigfoot, the most revered campers for quality will break when used as intended/marketed?
Weird.
Posted: 08/31/20 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
And OP, if you’re worried about it and the camper stuff clears it, leave the tailgate on for extra support if it seems necessary.
54suds
adk mts.
Posted: 08/31/20 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
I have a friend that has an older BF that is 11'5". Even on a long bed the rear of the camper has sagged quite a bit and caused a delimitation of the internal structure of the walls at the rear overhang. He fixed that but the sag was not much better.
Jim
sound advise i have worked on many different models of BF's that had the rear sag problem.
* This post was edited 08/31/20 06:24pm by 54suds *
2020 Chev 6.6 (GAS) lt regular cab ,drw,4x/torklift tdn's,
1999 Bigfoot 1011
Posted: 08/31/20 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Am I mistaken that Bigfoot markets “SB” models for short bed trucks?
Z-Peller
Oceanside BC
Posted: 09/01/20 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Original post says 9.6 short box camper on short box truck. Don’t see sagging issues with that. Old non basement BF’s had sagging issues, but haven’t heard of it with newer ones. Lots of plywood in the construction. Had my 2002 9.6 LB on LB truck for 14 yrs from Alaska to Texas to Maritimes with never an issue.
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
bigfootford
Posted: 09/01/20 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, I totally missed that the OP said sb 9.6... Thankyou...
Sorry OP for missing that...
My 9.6 lb on a long bed does sag a bit. Not bad but you can see it. It is a basement 9.6 2500.
Jim
Posted: 09/01/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Well those campers are piles of ____ then?
Thought BF was a good brand?
