RV.Net Open Roads Forum: Belts on 1994 Ford V10 engine on Fleetwood Southwind
 > Belts on 1994 Ford V10 engine on Fleetwood Southwind
rhudson1111
92647
Posted: 08/31/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone, I hope your all having happy travels! I'm about a month into my purchase of a 1994 Ford V10, class A motorhome. Now I'm getting a very high-pitched sound when accelerate on a cold engine. Called a mechanic for feedback and he states likely a loose belt. He said solution to problem will depend on if my 1994 Ford V10 has a V belt or a Serpentine belt. He said he was unsure which year Ford changed this. Does anyone know which type of belt the 1994 V10 has? Otherwise, I guess I can try to call Ford. Thanks, Robin
MrWizard
Traveling
Posted: 08/31/20 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I am unaware of any 1994 V10
1994 Ford F53 RV chassis is a 460 V8
Did the PO do a one off custom install?
With a crate V10, then you Need to get the engine number of the engine block in order to get the correct parts
Radiate The Happy
1997 F53 Bounder 36s
opnspaces
San Diego Ca
Posted: 08/31/20 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Are you asking because you're just curious? Or are you asking because you want to go to the parts store and buy a replacement belt? If you're not going to do the actual repair I would just take it to the mechanic and let them figure out which belts it needs.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
enblethen
Moses Lake, WA
Posted: 08/31/20 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
1994 Ford F53 is a v-8 7.5 engine.
Belts
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Lt46
Central Florida
Posted: 08/31/20 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, but Ford didn't put a V-10 in your 1994 motorhome. You should have the 7.5L 460 engine unless of course a previous owner retro fit you motorhome to fit the V-10.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
K Charles
Connecticut
Posted: 08/31/20 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
V10 ford was first made in 1997.
Chum lee
Albuquerque, NM
Posted: 08/31/20 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
You could either go to a Ford truck parts web site or to a Ford truck dealer, or any good auto parts store and give them your vehicle info and ask for what you want. (serpentine belt) Then see what they bring you. As others have said, you probably don't have a V-10, more likely a 460 (7.3 L) V-8. Or just look under the doghouse at the front of the engine.
A Ford Truck dealer may not be able to help you because of the age of your vehicle.
www.autohausaz.com Use 1994 Ford F350 with 7.3 L gas V-8 A place to start. You may also need a belt tensioner and idler pulley. Verify the length of the belt before you order. There are several different sizes.
Chum lee
dodge guy
Bartlett IL
Posted: 08/31/20 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
The 460 in your MH will have a serpentine belt. I would replace the belt, tensioner and any idler pulleys.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
RLS7201
Posted: 09/01/20 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Your 460 has 2 flat belts.
Rear belt goes from crankshaft to Power steering pump, to AC compressor, under tensioner, to water pump and back to crankshaft.
Front belt goes from crankshaft to water pump, to alternator, to smog pump and back to crankshaft.
Your squeal is most likely from the front belt. It is tensioned by adjusting the alternator.
While on the subject of F53 460s
Your 2 radiator hoses only fit a 460 MH and Motorcraft is the only supplier/manufacture. While some parts books show other brand names, they won't fit. Carry spares.
Lower hose....MOTORCRAFT KM4969
Upper hose....Motorcraft KM4941
Richard
* This post was last edited 09/01/20 09:53am by RLS7201 *   View edit history
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
