RV.Net Open Roads Forum: Tried towing after new tires & algnment...it did not go well
Search only in Towing
Open Roads Forum  >  Towing
 > Tried towing after new tires & algnment...it did not go well
Page of 5
campigloo
Baton Rouge, La
Posted: 09/01/20 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Did you check that they put the right tires on? A national chain put a new set of Michelin P rated tires on my ram 2500. It can happen.
Sandia Man
Rio Rancho, NM
Posted: 09/01/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Same thing happened to us after getting new tires, took a few hundred miles before the slickness of the new tread wore off to get back to the towing comfort we were accustomed to.
Sjm9911
New Jersey
Posted: 09/01/20 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
How old is your truck? I know you did an alignment but maybe there is something else in the front end that they forgot to do or tighten.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Posted: 09/01/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
2012 w 60k miles is what I picked up from the first post. And at 60k miles on original skins, it's been babied, not beat.
2017 Heartland Torque T29
blt2ski
Kirkland, Wa
Posted: 09/01/20 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
Add another, new tire squirm! Drive it 1000 miles or so, should be better.
Yes as others have noted, could also be too much psi front or rear of the tires. Possibly, but unlikely, wrong tires with too low a load rating, too low of pressure.......
Marty
Check RV.Net Blogs at: blog.rv.net
Cummins12V98
on the road
Posted: 09/02/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
YEP, good OL LesSchwab was famous for installing fatty tires on 3/4 ton trucks in a "D" rating saying "oh they have the same carrying capacity". BIG problem when towing there is a lot of bounce and poor handling.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Sjm9911
New Jersey
Posted: 09/02/20 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Reson why i was asking is that on my gmc( i know diffrent truck) there was sway links or something like that that went bad in the front end. Not sure on what it was called but would make the steering a bit wonky in the front.
HoosierDad
Indianapolis, In, USA
Posted: 09/02/20 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
bgum wrote:
You were running 65 and 75 but what is it now pressure wise?
Answer: Those readings were COLD PSI before I started towing.
Beverley&Ken wrote:
Same tire with the same tread pattern? same pressures, possible a 'new bad Continental tires,'
Does it handle the same without the trailer as it did before. Since you had the alignment done, start at there shop, maybe they can check the tires as well
Ken
Answers: Yes, same tire, tread pattern, and air pressures as the old tires. Truck handled the same as it did before without the trailer.
Answer: Yes, Tires checked and verified before I left the dealer as I accidentally did that to a car when I was 17 and working at a service station in 1980. Actually, I don't remember if I grabbed the wrong tires or they were handed to me but I'll take the blame for it.
I had the alignment checked and other than being a very small amount out it is fine and I had the tires balanced again just to make sure everything is good related to the tires. I'll get underneath it this evening and check the linkages to make sure there is no slop in them,
The truck has few miles on it because I have a short trip to work and we've not taken a lot of long vacations with it since we purchased it on early 2013. We mainly camp in State Parks in Indiana with the occasional long vacation trip.
We are skipping this weekend so Saturday morning I'll hook the trailer up to the truck again with sway and weight distribution bars and see if it is any better now that I have 900 miles on the tires.
I've never experienced tread 'squirm' in my 45 years of driving and pulling a trailer was quite the wild experience over 225 miles to the park and back. I guess I'll put the tires on in winter next time to get some miles on them before I tow as I don't want to experience that again.
Thanks for everyone's ideas and I'll report back on the pull test on Saturday and let you know if it is gone or getting better.
2012 F-250, Reg Cab, XLT, 4x4, 6.2L Gas
2012 Crossroads Cruiser CT29RLX
My Wife and I
Posted: 09/02/20 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Probably pertinent to the discussion, what size and model of tire?
Busdriver
Shepherdsville Ky 40165
Posted: 09/02/20 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Some times new tires will do that till broken in. Maybe you’re front end alignement is not right
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
Page of 5
