RV.Net Open Roads Forum: General RVing Issues: Bad Water Smell
 > Bad Water Smell
TechWriter
On The Road
Posted: 09/01/20 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
naturist wrote:
May I suggest using hydrogen peroxide instead of bleach?
A quart bottle in my 35 gallon fresh water tank pumped through the water system, including filling the water heater, and left for a couple days does as good as bleach.
"As good as bleach"? I disagree.
If you are using over-the-counter hydrogen peroxide (3% solution), then it won't be effective as a disinfectant.
To get something stronger like 12%, you'll end up paying about $20 for a 16 oz bottle.
Bleach is the most effective and least expensive disinfectant.
However, if you don't want to use bleach, then use Purogene.
naturist wrote:
Peroxide isn't hard on seals and hoses, doesn't leave behind any horrible and hard to flush out tastes and odors.
The RV myth that won't die. First, RV plumbing is either ABS or polyethylene. Bleach won't harm either. Finally, those "seals" in an RV are most likely made from bleach-tolerant Santoprene.
* This post was edited 09/01/20 05:07pm by an administrator/moderator *
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
Wherever I happen to park
Posted: 09/01/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Bleach can be bad for the water pump and seals.. Well yes. straight up
But 1/4 cup to 15 gallons of water is what we use to sanatize.. I might, in your case. go a bit higher. say 1/3 or even 1/2 per 15 gallons
And another factor is time.. 1 hour 2. hours a Week
The first.. Not so bad. the week. not so good
Then flush with a mix of water and baking soda. Use about one cup for your entire tank (Dilove in warm water and add to tank)
Then fresh water.
Give it the old SNIFF test. and last a taste test.
You might want to run the bleach mix 2 or 3 times fresh water flush in between
Be sure to pump it through EVERYTHING.
Home is where I park it.
mobeewan
Hampton, Va
Posted: 09/01/20 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
If your hot water still smells like rotten eggs even after sanitizing you may have to add some white vinegar to the water heater tank and let it set. It is recommended to remove the relief vale to pour it into the water heater tank, but you could also use the winterizing connection to pump it into the tank by opening the nearest hot water faucet to the water heater.
Drain the water heater first before filling it with 2 parts vinegar one part water. So for a 6 gallon water heater tank you'll need 4 gallons of white vinegar. You'll need a little extra if you use the winterizing connection but don't have to mess with removing the valve. This will also help to descale the water heater if it's needed.
Etstorm
Frankston,TX
Posted: 09/01/20 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
If you leave untreated water (no chlorination) it will go bad quickly. I drain mine and flush with vinegar.
cahillprc2
My house
Posted: 09/01/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you everyone. I was able to remove the foul smell with the bleach and using about 1/3 cup per 15 gal. I almost forgot the outside shower but caught it after draining the bleach water out and refilling with fresh water tank. The water coming out of the faucets was still smelling pretty bleachy even after a good 15-20 min so I figured that would sanitize the outside shower since we only use that for washing off feet and equipment or the dog. Tomorrow I'll drain it again and flush everything with the baking soda and hopefully the bleach smell with dissipate. At least with the strong bleach smell I can be pretty sure everything has been disinfected ??
Sjm9911
New Jersey
Posted: 09/01/20 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yea , you have to open and sanitize all the lines. If you miss one the bad stuff can get back into the system.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
cummins2014
Utah
Posted: 09/02/20 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Then fresh water.
I keep hearing this bleach thing, used it for 12 years on the same fifth wheel ,and never had an issue with anything. It sure seems like its the accepted method by many for many years . Once every spring works for me .
JimK-NY
NY
Posted: 09/02/20 07:57am Link  |  Quote  |  Print  |  Notify Moderator
cahillprc2 wrote:
......Tomorrow I'll drain it again and flush everything with the baking soda and hopefully the bleach smell with dissipate. At least with the strong bleach smell I can be pretty sure everything has been disinfected ??
Yes, your system has been disinfected. BTW, it is likely that the bleach smell will decrease within a few days. In fact I often leave some excess bleach in the system after sanitizing it. That will help to keep the water safe and fresh for a few more days until it dissipates.
garmp
St Louis, MO
Posted: 09/02/20 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar thing and traced it down to the hot water tank. Drained it,, pulled the anode and bought one of these. And was shocked at the **** that came out. Threw in some vinegar and let sit, then drained and all was well.
Our 2351D Phoenix Cruiser, Jack, has turned us from campers into RVers and loving it!
Coolerman
Paint Lick, KY
Posted: 09/10/20 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Just did my Sonic Venture water system in preparation for out fall camping trip.
I used Clorox bleach.
Added the 2 cups of bleach to the fresh water tank, then filled it completely. This also fills the hot water tank as I drain that tank every winter.
Ran water through all the lines until I smelled the bleach. Let it sit in the lines and tanks overnight.
Next I opened all line drains, and pulled the anode from the hot water heater to drain it.
Flushed the fresh water tank twice, closed all line drains then hooked to city water and flushed all the lines for 5 minutes.
The last thing I did was to mix up 2 gallons of water with a couple of ounces of bleach added and using a funnel, poured that into my 50' fresh water hose, tied the ends together and agitated that around for a couple of minutes, then let that sit for a couple of hours before attaching it to a hose bib and flushing for 5 minutes. NOW I am ready to go camping!
Mark Baker aka Coolerman
2016 Venture Sonic 170VBH
SOLD:2001 StarCraft Gemini
TV: 2018 Ford F-150 Lariat
 > Bad Water Smell
