RV.Net Open Roads Forum: Where does the little red wire go
 > Where does the little red wire go
Tom/Barb
Oak Harbor, Wa
Posted: 08/31/20 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Banks OttoMind engine calibration Module. There is a 4 wire cable that runs from the module to the instrument panel. the 4 wires are Black, (common ground) Green (gauge) and White (gauge) and then there is a red wire, that has a small blade connector. The red wire is disconnected and there is no obvious place for it.
This system worked until about 4 months ago.
Yes I know it is an old system, but it worked?
We installed a new back up camera, and this wire must have been disconnected behind the instrument panel some how.
I checked for + power, not powered
Bruce Brown
Northern NY
Posted: 09/01/20 04:06am Link  |  Quote  |  Print  |  Notify Moderator
Red is normally power. I would suspect it goes to a keyed hot in your fuse panel.
I could be wrong, but I'd also guess a call to Banks would also answer your question.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
rgatijnet1
Posted: 09/01/20 04:42am Link  |  Quote  |  Print  |  Notify Moderator
As mentioned red is usually for power. Perhaps it is used to power the back lighting at night.
enblethen
Moses Lake, WA
Posted: 09/01/20 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Not sure if this is your exact product. Page 16 says power.
Manual
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Tom/Barb
Oak Harbor, Wa
Posted: 09/01/20 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Manual
This is not a "Stinger pack' and this system is on a cummins 8.3 ISC
Thanks for helping.
enblethen
Moses Lake, WA
Posted: 09/01/20 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Go to Banks website with your exact product part number for the instructions if you don't have them.
What is your Banks part number?
Tom/Barb
Oak Harbor, Wa
Posted: 09/01/20 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
62663
enblethen
Moses Lake, WA
Posted: 09/01/20 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
I went through Banks site and didn't find your model number. You could try calling Eric Davis over at Eric's RV in Sequim. He did a lot of work with Gale Banks.
Tom/Barb
Oak Harbor, Wa
Posted: 09/02/20 12:16am Link  |  Quote  |  Print  |  Notify Moderator
that engine calibration module , is way of date.
banks is sending a owners manual for it.
But looks like I'm in for a updated module but not for banks.
enblethen
Moses Lake, WA
Posted: 09/02/20 06:23am Link  |  Quote  |  Print  |  Notify Moderator
I am surprised that Banks doesn't have obsolete manuals on website.
Good luck!
