RV.Net Open Roads Forum: Truck Campers: Front Frame Mount Tie Downs Not Working!
 > Front Frame Mount Tie Downs Not Working!
Page of 11
HadEnough
Traveling. Always.
Posted: 09/01/20 09:22am Link  |  Quote  |  Print  |  Notify Moderator
I have gone through so many sets of Torklift frame mounts I want to fix the problem permanently.
Why aren’t there bars run across the whole truck like for the rear tie downs? Those last.
My truck camper is sliding off to the passenger side now and both front frame mounts are broken. Again.
The camper is used on normal tarred roads only and never off road.
What’s are these things so defective/fragile?
Has anyone just run a piece of square tubing across the entire underside bolted to the frame with spacers and square u bolts to make a better frame mount?
* This post was edited 09/01/20 09:30am by HadEnough *
Near Annett’s Mono Village, Bridgeport, CA
Posted: 09/01/20 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Unusual issue.
HadEnough
Traveling. Always.
Posted: 09/01/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Unusual issue.
Really?
I’m not sure how front Torklift frame mounts, professionally installed, with and Arctic Fox TC, Torklift Fastgun tie downs and a Dodge Ram 2500 (with proper Dana axle, air spring/bags, leaf spring reinforcements, hight weight load wheels and tires) is that unusual.
The mounts fail at the top of the triangle every time.
They last months, not years.
Kayteg1
California > Nevada
Posted: 09/01/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Isn't Torklift giving lifetime warranty?
Their front tie-downs work on my 2017 Ford just fine.
Camper scaled 6000 lb and survived Alaskan highway.
So how about a picture?
jimh425
Western MT
I agree that’s an unusual issue. Maybe your tiedowns are not properly adjusted. Or maybe, your suspension is so jarring that they are breaking.
joerg68
St. Ingbert, Germany
Posted: 09/01/20 10:19am Link  |  Quote  |  Print  |  Notify Moderator
I have never heard of this problem happening, so yes, to me it sounds unusual. I had no problems in 11 years on 2 different trucks (2008 Silverado 2500HD, 2014 F-350). What do the people at TL say?
kohldad
Goose Creek, SC
Posted: 09/01/20 10:46am Link  |  Quote  |  Print  |  Notify Moderator
With the design, it's hard for me to imagine them breaking without doing damage to the frame and/or the bed. Would you please post a picture of your install.
Are you using the torklift spring loaded tiedowns? Or are you using chains with turnbuckles and trying to put enough pressure on them to keep the camper from moving around? You aren't suppose to pull on the tie down hard enough to keep the camper from moving around. That will happen even on normal roads.
Do you have a plastic bed liner? The camper will easily move around with one. Most camper manufacturers and Torklift say not to use a plastic liner.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Seminoe Joe
Texas, Wyoming, or somewhere in between
Posted: 09/01/20 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Weird. Agree it’s an unusual issue since I’ve had not problem with TorkLift tie downs and don’t know if anybody that has had problems as described in the OP.
Shrug.
Perhaps the truck is the problem?
“It’s all in the reflexes.”
2012 Lance 850
2012 Chevy 2500 HD
HadEnough
Traveling. Always.
Posted: 09/01/20 11:04am Link  |  Quote  |  Print  |  Notify Moderator
This may be the issue. It knocks my teeth out l too, it pretty close to it.
Still, you’d expect the frame mounts to survive bumps.
HadEnough
Traveling. Always.
Posted: 09/01/20 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Yes, using the normal Torklift fastgun tiedowns. Straight from camper tie down hole to Torklift extension piece that slides into the frame mounts.
Yes, I have a rubber mat in the bed to keep the TC gripping and in place. Trouble is, there isn’t enough downward pressure to hold it on the mat since both frame mounts are now broken.
I’ll post some pictures as soon as the weather improves. It’s wet and raining.
* This post was edited 09/01/20 11:13am by HadEnough *
Page of 11
