RV.Net Open Roads Forum: Travel Trailers: How to tow & push BACKWARDS?
 > How to tow & push BACKWARDS?
valhalla360
No paticular place.
Posted: 09/02/20 04:47am Link  |  Quote  |  Print  |  Notify Moderator
If you do a hitch on the rear, make sure it's attached to something solid. Not the typical paper thin rear bumper you find on most trailers.
Also, you might consider something like a pintal hitch as you are going to have a fairly large negative hitch weight (probably in excess of 1000lb on a 7000lb trailer). I wouldn't want to be pushing from the rear and have it pop off a ball.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
bgum
South Louisiana
Posted: 09/02/20 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Did you say that a motorized trailer dolly rolling on plywood can't put it in place.
Posted: 09/02/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Motorized dolly? $1500-2000 to move a trailer basically once? Lol
Stop overthinking it. Unless it's up a hill, run the trailer jack on plywood and have a couple helpers push it into place, or use a neighbors 4 wheeler (same guy that would help push for a cold beer or 2).
I can push a 5-7klb vehicle or trailer on flat pavement by myself. Surely a few people can push it into it's final resting place.
2016 Ram 2500, MotorOps.ca EFIlive tuned, 5ā€ turbo back, 6" lift on 37s
2017 Heartland Torque T29
bpounds
Sophmore Brain...
Posted: 09/02/20 11:23am Link  |  Quote  |  Print  |  Notify Moderator
There is little concern about the bumper thickness, since this is just a device for short moves in his yard. And there won't be any negative or positive hitch weight, since a tow bar is hinged at the trailer attachment points. Weight will still be on the front trailer jack as usual. The tow bar acts as a steering and pushing device, not much else.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
valhalla360
No paticular place.
Posted: 09/02/20 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
If the OP is still going to buy a dolly, that is partially true (it would eliminate the hitch weight being negative).
I still wouldn't trust the typical rear bumper not to cave in.
campigloo
Baton Rouge, La
Posted: 09/02/20 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Since you have access to a dolly Iā€™d go the plywood route. Rip a sheet of 3/4 and lap the ends.
spoon059
Just north of D.C.
Posted: 09/03/20 06:43am Link  |  Quote  |  Print  |  Notify Moderator
A1ARealtorRick wrote:
afidel wrote:
My concern would be local and/or state ordinances about occupation of a trailer as a residence. I know where I'm at that's a complete non-starter and I assume California is even more strict as far as regulation. Before you sink a bunch of time and energy into this you'd be smart to look into the legalities of what you're thinking of doing.
^^^ What he said
I can think of about a dozen reasons why this sounds like a bad idea to me, but he isn't asking, so why are you guys offering?
2015 Ram CTD
2015 Jayco 29QBS
2012Coleman
Posted: 09/03/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
It seems to me that if you towed it it - the door would be on the wrong side.
And I have stayed in an Airstream AirB&B - it was plenty cool. Don't knock it till you have tried it.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
GrandpaKip
Flat Rock
Compact tractor. Mine is only 5ā€™ wide and would move the trailer just fine.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Jebby14
Windsor Ontario
Posted: 09/03/20 10:09am Link  |  Quote  |  Print  |  Notify Moderator
if turning is the problem cant you just back it in
Q: Whats brown and sticky???
A: A Stick....
