RV.Net Open Roads Forum: bubble on EPDM roof by the seam
 > bubble on EPDM roof by the seam
ksg5000
Oregon
Posted: 09/02/20 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Mont G&J wrote:
Leave it alone. Never cut a perfectly good roof covering that is not leaking. Often times those bubbles come and go with temperature changes.
X2. If you have cut it then you should consider a small Eternabond patch.
Kevin
wanderingbob
monticeeo, fla
Posted: 09/03/20 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have several times with the same situation drove brass carpet tacks into the roof and taped or eternabond over .
