RV.Net Open Roads Forum: Class A Motorhomes: Workhorse oil cooler lines/hoses
 > Workhorse oil cooler lines/hoses
mrracechaser
Where ever my motorhome is
Posted: 09/03/20 06:27am Link  |  Quote  |  Print  |  Notify Moderator
I developed a pin hole in one of the oil cooler lines that runs from the block to the cooler. This is a common problem when the bracket breaks that holds the lines in place where they go thru the area below the motor mount and the line rubs on a bolt until it wears thru.
Before you go anywhere crawl underneath and have a look. It might save you a breakdown on your next trip. I would recommend some wire ties even if the bracket isn't broken yet.
Vince Sadowski
rgatijnet1
Posted: 09/03/20 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Besides the oil cooling lines there are also transmission fluid cooling lines that can have the same issues.
