RV.Net Open Roads Forum: Travel Trailers: A/C ducts
 > A/C ducts
Bears Den
Estero, Fl.
Posted: 09/03/20 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Can access to the a/c ducts be gained by removing the shroud on the roof? I have four a/c vents and two have good air circulation in the rear of the trailer and two are not blowing any air at all in the front of the trailer. The vents at the a/c unit are closed. Checked for any obstruction and leak from within the trailer. Not sure how to access the ducts at the a/c unit itself. Thanks for the help. By the way, TT is a 2014 Kodiak.
2014 Kodiak 279 rbsl
2017 Ford F-150 King Ranch V8
Equalizer hitch
Ford integrated brake controller
2004 Travel Lite 23S Hybrid Travel Trailer ( previous trailer )
1998 Viking Popup ( previous trailer )
No substitute for experience
CA Traveler
The Western States
Posted: 09/03/20 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the inside A/C cover.
2014 Grand Cherokee Overland
Bob
jdc1
Rescue, Ca
Posted: 09/03/20 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Or remove the supply vents.
MFL
Midwest
Posted: 09/03/20 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
May need to remove both of above mentioned, and use a light and mirror to look for obstructed run to vents. Of course if you have a fancy lighted camera, that extends into the vents, would be best option.
Jerry
mooky stinks
Cicero,NY
Posted: 09/03/20 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
I've had the piece that was hole sawed out of the ceiling stuck in the a/c ceiling vent. Anything goes with quality control in the rv industry.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
9600lbs scaled
Blazing Zippers
North Idaho
Posted: 09/04/20 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
There are several videos on YouTube addressing the AC loss by checking the unit from inside. They all seem to tape and smooth corners and crannies that are not installed correctly.
Then I would try the old fish tape and flashlight search and seizure of junk in the ducts.
At the ends of the ducts, some folks place a block of sorts to stop all movement of air past the furthest opening. Some say the ducks just open into the ceiling cavity. I did that and it seemed to improve air flow into the bedroom area in a Keystone product.
Whoooo knows? You might find a treasure up there.
parcany
Arizona City
Posted: 09/05/20 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have done this an our last three Jaycos and it has helped. Also took out all of the ceiling vents and wrapped Gorilla tape around the upper cone and put them back in. That seemed to help also.
deltabravo
Spokane, WA
Posted: 09/06/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Here's one of those videos
Here's what the A/C looks like when the interior cover is removed.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
 > A/C ducts
