RV.Net Open Roads Forum: Truck Campers: Back order shocks
 > Back order shocks
towpro
Compass PA
Posted: 09/12/20 06:39am Link  |  Quote  |  Print  |  Notify Moderator
I always had the problem on my Pickup camper trucks with needing shocks with more dampening to help with sway, but with camper off that same shock would be over hard and ride rough. I tried those adjustable ones but they had other problems (returned them)
now that I have a motorhome I don't have the option of removing the camper, but had same problem, the stock Mercedes shocks were designed for a van body and were too weak.
Than someone introduced me to Agile Offroad. This guy builds shocks for off road racers, but also happens to own a Mercedes Motorhome, so he went to work on re-valving a fox 2.0 shock for his motorhome. Best money I ever spend on rear shocks. solved my problem. Maybe call him and see if he has a valving solution for your truck that would work loaded or unloaded?
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
brholt
Seattle
Posted: 09/12/20 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Just replaced the factory shocks with KYB Monomax shocks. Very pleased with the results
Hemi Joel
Minnesota
Posted: 09/12/20 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely wait for the adjustable Rancho 9000's. Every setup is different, requirements vary. With the 9000's you can adjust them to suit. With bilstien, you are stuck. I spent big $$ on Blistien 4600's, and they were worse than the old monroes I took off. I lost $$ getting rid of the bilsiens, and going with 9000's on the rear which I love, and monroe gas on the front, which are just barely OK, but better than the bilstien. They don't make 9000's for the front of my truck, I wish they did.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
Bert the Welder
Van. Island
Posted: 09/13/20 12:27am Link  |  Quote  |  Print  |  Notify Moderator
Adjustable is great...while it's working. Just wish the Rancho's were better quality. Knobs fail and then powder coat is garbage. Sure you get life time warrenty, but you still gotta pay for the removal and install.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
jimh425
Western MT
Posted: 09/13/20 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I had adjustable 9000s on my SRW with the same TC. They were a good bandaid for a combination that was stretched to the max. My F450 with Bilsteins is a much better combination and much better ride, but I also am not stretching the capability any more.
In any case, I think both shocks have a reason to be. If your setup is stretched near the limit, and you ride empty a lot, the 9000s are a pretty good solution.
I remember one time I was riding empty on a gravel road that I almost bounced the SRW off of at 25. I had my tailgate on, but otherwise, I was in hauling mode. My tire pressure was up and the 9000s were up as well. After turning the shocks down and dropping the pressure, I felt much safer. The point being, the 9000s really do slow the suspension and make it much stiffer. YMMV.
thedavidzoo
Tucson, AZ
Posted: 09/13/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
We just installed 4 Rancho 9000 XLs yesterday. Rear was easy, front was a pain. Dealer wanted too much for shocks and labor, over $1000. DIY cost us $380 total from Shocksurplus.com.
Haven't been out with them yet. We'll see if we can tell a difference.
2014 Ram 3500 CrewCab Diesel DRW 4x4 4.10 Aisin, Torklift Fastguns, Upper Stableloads, Timbrens
2017 Northstar 12' STC
640W solar, 400Ah lithium LiFeMnPO4 batteries
Mike and Terry Ann
Trout run, pa
Posted: 09/13/20 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Buzzcutt , order them from Advance auto . Told they were made over sea and they don't know how long they will be on backorder. Current shocks are shot ( leaking) so I can't wait long. Given the times we live in now I don't have much of a choice.
Buzzcut1
Norcal
Posted: 09/13/20 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
check the part here. most are in stock
https://www.summitracing.com/search/depa........uct-line/rancho-rs9000xl-shock-absorbers
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
towpro
Compass PA
Posted: 09/14/20 07:42am Link  |  Quote  |  Print  |  Notify Moderator
I put 9000's on the back and 5000's on the front of a 2015 Ram 4wd (with Rancho's engineers blessing). with camper on, even with socks on stiffest setting (I tried many settings) I would hit this dip in the road and the rear of the truck would start to oscillate and only way to stop it was to slow down.
Rancho said the rear ones might be bad so they replaced them. Same problem with new next rear set. So I returned them all under that 90 day free ride program.
I put the stock shocks back on and left it that way.
I also noticed the 9000 did not extend themselves if you compressed them, you had to pull them to extend them (but the 5000's did). I seem to recall when I questioned this they said they were not gas charged. But now I see on the website that are gas charged so maybe they redesigned the 9000's.
also many people said that to remove the adjuster and grease it as thy rust shut over time.
Bedlam
PNW
Posted: 09/14/20 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
I had the adjustable Rancho shocks on my F250. I found once I tuned the front, I did not touch them but the rears would be adjusted based on whether the camper was loaded. I think you can get away with a fixed set up front, but you will not get that fine tuning of the 9000 series.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
 > Back order shocks
