RV.Net Open Roads Forum: Tech Issues: Gas leak on Atwood 8531-I’ve dclp
 > Gas leak on Atwood 8531-I’ve dclp
MrWizard
Traveling
Posted: 09/04/20 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Gas leak detector spray
Order online,
RV store,
Hardware store
Red stuff in finger pump spray bottle
Better than soapy water
Radiate The Happy
1997 F53 Bounder 36s
oldbubblehead
Raleigh
Posted: 09/25/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Received new valve assembly for the furnace and installed. Tested outside RV first. No leaks detected and no gas smell. Started furnace ok.
mobeewan
Hampton, Va
Posted: 09/26/20 12:59am Link  |  Quote  |  Print  |  Notify Moderator
On an older trailer I had, my dad said he could smell the propane when the furnace was running. Later I found the furnace shut-off valve was leaking through the valve stem. It was worse when I pushed down on the valve stem. I shut off the propane at the cylinder. Since I was running the generator for his CPAP I plugged in a small ceramic heater to keep us warm the rest of the night.
ajriding
st clair
Posted: 09/26/20 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Did u solve it?
The furnace has a "soleniod" valve on it. Those are operated with electricity, and can leak. I wanna say they are about $40 or so, and can be replaced, so if the unit is old this could be a likely source of the leak, very hard to find with soap bubbles.
What is this red spray mentioned previously?
RLS7201
Posted: 09/26/20 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I have experienced 2 propane leaks where the copper line cracked at the flair.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
RLS7201
Posted: 09/26/20 11:51am Link  |  Quote  |  Print  |  Notify Moderator
delete
