RV.Net Open Roads Forum: Tow Vehicles: My 2019 Ford F 150 towing
Search only in Tow Vehicles
 > My 2019 Ford F 150 towing
Johnny Hurryup
Tafton Pa.
Posted: 09/03/20 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
I bought this truck a few months ago. It has the trailer hitch 7 pin connector and on the dash, a screen for towing info. But it has no brake controller with some kind of gain control. I'm shopping for a travel trailer. What do I need?
MFL
Midwest
Posted: 09/03/20 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
You can get an after market brake controller, that should be a plug play, with a connection under the dash. A connecting wire harness used to come in the glove box of a new truck, that fits the under dash plug-in. Not sure, but may also be possible to get a Ford IBC installed.
Jerry
riven1950
NC
Posted: 09/03/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Check your payload sticker to see what you have to deal with. That will tell what you might want to tow.
We had a 2004 F150 and added a controller with no problem but the truck was not set up for heavier TT's. But it did fine for the smaller TT we had at the time.
Sjm9911
New Jersey
Posted: 09/03/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
https://youtu.be/xGSxTjojnio
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Lone Pine, CA
Posted: 09/03/20 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
You NEED to tell us your truck’s max trailer weight AND payload. Then tell us how much weight you’ll carry in the truck.
Mike134
Elgin
Posted: 09/03/20 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend the Ford integrated brake controller.
You'll find this forum advise seems to limit a F150 to 6000lbs the F150 forum folks are comfortable up to 8000lbs.
here's a link to get you started
https://www.f150forum.com/f118/adding-trailer-brake-controller-483714/
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Lone Pine, CA
Posted: 09/03/20 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
And just forget about payload, Mike? That makes me uncomfortable. OP is alone in the truck? Or a family of five? OP carries no gear in the truck? Or generator, three bikes and tools?
Some F150s are tuff, and some are wimpy just like Chevy and RAMs. OP hasn’t told us a thing about his truck and you recommend a possible 8000 pounds? Irresponsible.
Most F150s are not 1903 pounds of payload.
theoldwizard1
SE MI
Posted: 09/03/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Usually Ford upgrades the radiator and transmission cooler for their HD Trailer Tow option.
What is your rear axle ratio ?
Sjm9911
New Jersey
Posted: 09/03/20 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Really? I never owned a ford in my life, but i dont think a break controller will up the tow limits on the trailor 2000 lbs. That just dosen't seem right. Now if the ford allready has it, it could mean that the TV has other upgrades, like better cooling, transmistion, gearing. But to say the controller can give you more power can not be right.
Mike134
Elgin
Posted: 09/04/20 05:03am Link  |  Quote  |  Print  |  Notify Moderator
Sorry you misunderstood me.
The "weight police" on this forum seem to think the practical limit of a 1/2 ton towing weight is 6000lbs. The "weight police" on the ford forum have it at a more reasonable limit of 8000lbs when looking for advise on trailers
