Sabre3
Halfway to where you want to be
Hello,
This is my first post and I come looking for some help.
I have a 2018 Winnebago Winnie drop. The slide out quit working and I can't seem to figure it out.
I discovered a chaffed wire where the wiring bundle goes through the floor, I replaced that wire from the control box to the auto-resetting fuse.
I replaced the auto resetting fuse on the inside of the left front frame rail.
There were no lights at all on the control box (Lippert #13398-DO)
So I bought a new control box and still no worky
Looking for some ideas?
The slide out makes no noise at all. No effort to operate
edited 09/03/20 09:14pm by Sabre3 *
afidel
Cleveland
Did you check for 12V input coming into the control box before replacing it?
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
Sabre3
Yes, there is power coming into the control box. How would I check to see if power is coming out of the box?
afidel
Cleveland
I would backprobe the harness connector at J2 and J3 on the black and red pins using my multimeter, if your probes are too big for that then use a pin to packprobe and hook your leads to the pins.
