RV.Net Open Roads Forum: Travel Trailers: Dually towing TT
 > Dually towing TT
Jethroish
Scottsburg, IN
Posted: 09/04/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Since I am towing a TT with my dually, I am posting here rather than the tow vehicle forum.
Since 2004, I have only towed a "bumper pull" when pulling my utility trailer. Aside from that, I have been towing a 5er or goose neck horse trailer.
We have just bought a 29ft TT with dry weight just under 4200#.
Not concerned about weight distribution, but...
...for those towing with a dually, do you use sway control?
Bringing the trailer home, I did not really notice any sway. Just a little "tracking" on road grooves.
Thanks
EDIT: Clarification...pulling home, the trailer was tracking a little bit, which I attributed to ruts/grooves in the lanes.
Do those that use a dually to tow a TT, do you use a sway bar or any type of sway control hitch?
* This post was edited 09/04/20 05:05pm by Jethroish *
Don't let your work become your life.
2018 RAM 3500 Dually 4x4 crew cab,
2015 Shadow Select 4 horse LQ w/slide out
2021 Jayco JayFlight SLX 264BH
azdryheat
Tucson, AZ
Posted: 09/04/20 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
We tow long TT's where I work and we don't use sway control with our duallies.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Mfan
Otsego,Mi
Posted: 09/04/20 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I believe that the trailer sways, not the truck.
Death Valley NP
Posted: 09/04/20 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
If you have enough tongue weight you shouldn't have a sway issue. Your truck heavily out weighs your TT.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Posted: 09/04/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Posted: 09/04/20 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
No, you don’t need any of that stuff with a truck that big for that light of trailer.
Would only need sway control it it’s a TT with horrible weight distribution anyway.
guidry
Texas Cajun
Posted: 09/04/20 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
In an emergency if the trailer is swaying you can just tap the brake controller to bring it back in line as you slow down. I'd recommend the sway control.
bpounds
Sophmore Brain...
Posted: 09/04/20 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I never used sway control unless also using weight distribution.
Having said that, every trailer is different. I would pull it first and then decide. Some trailers just pull great, and some don't, and some don't pull really nice even with a sway control.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
routeforty
ohio
Posted: 09/04/20 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Towed a TT same length as yours, about 1500lbs heavier many thousands of miles with a dually. Never used WD or sway bars. Only time I ever had any sway was with a utility trailer that was loaded with way to much weight on the rear & not enough on the tongue(my fault). Kept the speed low and all was ok.
2018 coachmen leprechaun class c
Huntindog
Phoenix AZ
Posted: 09/04/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
I have towed TTs with a CC diesel dually since 2001. I always used WD with sway control. I am very picky about my setup... Having it dialed in the best it can be, can pay off once in awhile when things go horribly wrong. My TTs were heavier than yours, but I could tell the difference of a one washer adjustment on my EQUALIZER.... Many may not feel the difference, but I am picky.
With a TT as light as yours, I may forgo the WD especially if it is a diesel, but would use a friction sway control for sure... It is kind of like seat belts... You don't need them until you do.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
540 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
 > Dually towing TT
