RV.Net Open Roads Forum: Travel Trailers: Newbie trailer owner, quite confused
 > Newbie trailer owner, quite confused
bgum
South Louisiana
Posted: 09/05/20 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Do not plug it into any house plug that "looks" like your trailer plug. Use only normal wall plugs that are 120 volts and you should not try to run your trailer Air conditioner on that. If in doubt make sure the plug is NOT 220 volts. When plugged into house plug you can operate all 120 volt items except A C but not all at the same time. Microwave or water heater one at time. As you learn more you will learn what can be run at the same time. This will get you started.
Huntindog
Phoenix AZ
Posted: 09/05/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
It is a good idea to turn off the breaker to the receptacle you are pluging into.
The reason is that if it is live, it will arc a little everytime you plug in. After awhile this arcing will damage both the power cord and the receptacle.
That is the only breaker that you need to turn off to prevent this.
Welcome to the RV world.. Have fun.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FBP, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
300 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
RetroAirBnB
California
Posted: 09/05/20 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Very helpful. Thank you. I just ordered the adapter
profdant139
Posted: 09/05/20 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Retro, don't try to run the air conditioner off your house power unless you have a circuit that can handle that load and unless you have a beefy extension cord.
And on a larger note, don't stop asking questions!! There is a bit of a learning curve for trailer owners -- it is not rocket science, but there are tips and tricks that you will pick up.
Don't be discouraged --all of us old timers were newbies once -- and take time to laugh at the mistakes you will make.
Speaking as someone who has been doing a lot of trailering during the last 15 years, my only regret is that I did not discover RV travel until I was in my 50s. I missed out on a lot of good years.
Welcome to the club!!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
RetroAirBnB
California
Posted: 09/05/20 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
This is great. thanks so much!
wanderingbob
monticeeo, fla
Posted: 09/05/20 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Many garages in older homes will have an outlet that looks like an RV plug , it probably is not an RV plug but is a 220 volt dryer plug . If ya plug in there it will blow a lot of stuff in your trailer and all your babies will be born naked !
time2roll
Posted: 09/05/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
RetroAirBnB wrote:
OK, but maybe you can tell me this: can i connect to my home power? Manual says I can, but have to turn off all breakers in house and trailer first, then turn on. For some reason.
A regular 120v outlet with an adapter, yes. You will have limited power to charge the battery and maybe run the fridge. Anything big will trip the home breaker. Reduce the load and reset.
DO NOT plug into a large dryer outlet even if the prongs look similar. They are not compatible. The smoke will come out.
Turn off main breaker in the RV is fine. Some items are on and will cause a spark as you plug in. Best to avoid the spark and related voltage surge.
675w Solar pictures back up
Taxman2436
Holden, MA
Posted: 09/05/20 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Check this out and the other links provided. I am a newbie also and besides the great advice here, this has also been helpful.
http://rvservices.koa.com/rvinformation/rvmaintenance/basic-rv-electricity.asp
Lenny
Taxman2436
Holden,MA
2019 Ford F-250 6.7 L Diesel
2018 Cruiser Shadow
Seon
Lake Camanche, CA
Posted: 09/05/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
OP should list where in California he's located then maybe a fellow RV'er nearby can swing by and help him.
